help!!! failed smog by HC
Old Nov 3, 2004 | 05:49 PM
vile10's Avatar
Default help!!! failed smog by HC
@ 15mph, allowed 56, measured 74
tried sea foam, changed spark plugs, didn't help, what to do next?
Old Nov 3, 2004 | 07:08 PM
Grand141's Avatar
Default Re: help!!! failed smog by HC (vile10)
try changin the O2 sencor
Old Nov 3, 2004 | 07:22 PM
drdisco69's Avatar
Default Re: help!!! failed smog by HC (Grand141)
If you can, advance the timing a bit too.
Old Nov 3, 2004 | 07:59 PM
Gant's Avatar
im a smog tech in cali
advancing the timing will raiser ur nox levels, what are ur co levels? seems like ur not failing by much mite be a new cat , i doubt bad o2 those readings are to high for bad o2
Old Nov 4, 2004 | 09:21 PM
vile10's Avatar
Default Re: (Ba4)
i was told to retard timing?
Old Nov 4, 2004 | 09:54 PM
Gant's Avatar
are u in cali? u can retard timing IF ITS WITHIN SPECS, sure u can pass smog if u retard ur timing all the way but remember we check ur timing in the smog test
we have a book or look under the emissions label under ur hood
says 14btdc + or - 2 degrees lets say, that means u can advance it two degrees and you'll pass timing check or u can retard it two degrees and pass timing check..go 3 degrees either direction and u fail,
if manufacturer doesnt give a plus or minus, then default is plus or minus 3
Old Nov 5, 2004 | 12:03 AM
Rostr02's Avatar
Default Re: (Ba4)
although this does not help you I failed HC by 5 times over the legal limit in pa with a brand new cat
Old Nov 5, 2004 | 04:32 AM
rsbad454's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vile10 &raquo;</TD></TR><TR><TD CLASS="quote">@ 15mph, allowed 56, measured 74
tried sea foam, changed spark plugs, didn't help, what to do next?</TD></TR></TABLE>
change the cat for sure......i just had to smog my 91 chevy truck and i failed for the same item: Hydrocarbons.... I had the limit of 98 at 25MPH, but it measured 107 so i failed. I had my friend install a new cat, this time it measured 54....the cat is usually your answer. To be safe, i'd say replace the O2 sensor(s) and oil, along with 91+ octane.
Old Nov 5, 2004 | 04:40 AM
drdisco69's Avatar
Default Re: help!!! failed smog by HC (rsbad454)
Some people don't realize what an oil change can do for emissions.
Old Nov 5, 2004 | 05:11 AM
rsbad454's Avatar
Default Re: help!!! failed smog by HC (drdisco69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 &raquo;</TD></TR><TR><TD CLASS="quote">Some people don't realize what an oil change can do for emissions. </TD></TR></TABLE>
I concur......especially if the engine has higher mileage....think about the fuel that contaminates the oil. I forgot to mention this.....
Old Nov 5, 2004 | 05:51 AM
crx_88_si's Avatar
tell us ALL your readings...
Old Nov 5, 2004 | 06:09 AM
EFz6er's Avatar
Default Re: (crx_88_si)
I just failed HCs too and my timing was retarded and I now have advanced it and Im going back thru this afternoon. I will let you know if advancing help HC levels go down
Old Nov 5, 2004 | 10:54 AM
vile10's Avatar
thanks to you all, i am planning to do a minor tune up, w/ wires, cap and rotor, and retard timing 2 degree and try again
Old Nov 8, 2004 | 09:17 PM
vile10's Avatar
Default Re: (vile10)
anyone has update yet?
apaige58
10
Aug 5, 2013 04:36 PM
GsR-Freak
Apr 1, 2005 11:37 PM
haophat
Jan 21, 2004 08:30 PM
ITR#00-1077
May 21, 2002 01:03 PM
