searched and found way to much stuff to answer this ?...
Old Nov 3, 2004 | 04:16 PM
Nic's Avatar
Nic
Default searched and found way to much stuff to answer this ?...
Gm syncromesh in a cable tranny....good or bad?
What fluid do you guys use? I KNOW IT TAKES 10w30 motor oil.
Old Nov 3, 2004 | 04:30 PM
Spaceballsthelunchbox's Avatar
No Big Whoop
Default Re: searched and found way to much stuff to answer this ?... (stk crx)
nope! if it's made by honda, it uses Honda Manual Transmission Fluid.
You get it at the dealer, and don't bother coming up with your own recipe.
Old Nov 3, 2004 | 04:31 PM
EL Vap133's Avatar
Is your tranny grinding?
Old Nov 3, 2004 | 04:40 PM
civickiller's Avatar
Default Re: searched and found way to much stuff to answer this ?... (EL Vap133)
i put it in my tranny because it grinded 2nd, still grinds 2nd on fast shifts.
Old Nov 5, 2004 | 01:56 PM
Nic's Avatar
Nic
thanks for the replies. My tranny is dead I lost first gear so I am looking at picking up a used one and it being a 91 miles are gonna be high I want to put the best fluid in it I can.
Old Nov 5, 2004 | 02:03 PM
eumoria's Avatar
Default Re: (stk crx)
Synchromesh is good but only to get rid of grinds... it's not a cure-all for transmissions.
And use Honda Genuine Transmission fluid. Trust me, you'll be happier with it. If you have grinds just follow the directions to the synchromesh and it should smooth them out. But it truly just covers them up, it doesn't repair your synchros.
1 - Remember to always fully depress your clutch when shifting.
2 - Don't keep your foot on the clutch all day (pretend it's on fire... don't sit at an intersection with your foot on it).
3 - And if you smash a gear don't force it. Go back to neutral... reseat clutch and go again.
Those 3 things should preserve your throwout bearing and your synchros. But with hard driving and heavy shifting it's impossible to keep them forever. During daily driving be nice to your tranny, and it'll be nice back.
Old Nov 5, 2004 | 02:05 PM
Nic's Avatar
Nic
Default Re: (eumoria)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eumoria &raquo;</TD></TR><TR><TD CLASS="quote">Synchromesh is good but only to get rid of grinds... it's not a cure-all for transmissions.
And use Honda Genuine Transmission fluid. Trust me, you'll be happier with it. If you have grinds just follow the directions to the synchromesh and it should smooth them out. But it truly just covers them up, it doesn't repair your synchros.</TD></TR></TABLE>
Well I hope the tranny I do end up getting wont have grinds but I dont want to take the chance of it grinding so I want to put in good fluid to help lessen the chance of grinding
theresyourproblem
Sep 16, 2007 01:26 PM
hondahustle
Jun 20, 2007 10:26 AM
Brolli007
Dec 22, 2002 12:09 PM
DeDonDeRosa
Jul 30, 2002 01:08 PM
EleanoR
Dec 13, 2001 07:54 AM
