bad suspension?
Old Nov 3, 2004 | 03:04 PM
redboost10's Avatar
Default bad suspension?
i just bought a 97 honda civic cx and it has skunk2 coilovers. it is pretty low and does not have a camber kit on 17" rims. when i accelerate the steering shakes very bad. im planning on getting the tein type flex coilover system and putting some 15" rims on it. and i will try to adjust it to stock ride heighth. is this shaking from the big rims, bad camber, and not so good coilovers?
Old Nov 3, 2004 | 04:24 PM
suspendedHatch's Avatar
Default Re: bad suspension? (tgh99si)
Sounds more like a tire is out of balance. Is there any damage to the rims? Shaking is not a symptom of anything you mentioned.
Old Nov 3, 2004 | 05:06 PM
FitCRX's Avatar
Default Re: bad suspension? (shaundrake)
its your controll arms....try some new bushings
Old Nov 3, 2004 | 09:12 PM
redboost10's Avatar
Default Re: bad suspension? (FitCRX)
tires are balance, check that when got the alignment. illchange the bushings. thank you
2kdrift
Suspension & Brakes
15
Oct 15, 2015 04:20 AM
CRX Toad
Feb 15, 2005 10:23 AM
redboost10
Nov 3, 2004 04:13 PM
hatchback
Apr 15, 2003 05:55 PM
dominate9
Feb 3, 2003 04:47 PM
