Bad wheel bearing?
Old Nov 3, 2004 | 02:41 PM
Ricochet.'s Avatar
Default Bad wheel bearing?
My car shakes a little with speed, but no matter what speed I'm at, about 2/3 the time when I floor it the entire car gets pretty shakey. Could this be a bad wheel bearing? I just had my axles replaced with b16a2 abs shafts after having two torn boots on my ctr ones.. Maybe they were junk replacements? Please help, this is really annoying.. it almost feels like wheel hop.
Old Nov 3, 2004 | 02:53 PM
smart monkey's Avatar
Default Re: Bad wheel bearing? (Ricochet.)
you might have bad axles
Old Nov 3, 2004 | 02:58 PM
beaterdriver's Avatar
jack the car up, and see if you can shake the wheel vertically, if there is movement, bad wheel bearing
Old Nov 3, 2004 | 03:08 PM
Top-Fuel's Avatar
Default Re: (beaterdriver)
Good to know cause I think i have bearing problems as well. When I drive it sounds like there is this whinning type of sound and somtimes pulls to one side my car. Could also be wheel alignment....
Old Nov 3, 2004 | 03:40 PM
Ricochet.'s Avatar
I'll try that, thanks for the help
Old Nov 3, 2004 | 03:42 PM
93CivicSI's Avatar
wheel and tire balance
Axles
Flywheel weights
BAD alignment
bad ball joints
bent or damaged tie rods.....
just for starters...
Old Nov 3, 2004 | 03:45 PM
daver's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beaterdriver &raquo;</TD></TR><TR><TD CLASS="quote">jack the car up, and see if you can shake the wheel vertically, if there is movement, bad wheel bearing</TD></TR></TABLE>
that could indicate balljoints too.
In my experience, 4 times out of 5, a vibration is wheels/tires. If it started right after this axle replacement tho....
d
Ricochet.'s Avatar
I already had my wheels and tires balanced along with an alignment. I don't see what I could have done to cause it to shake, it just started doing this and I haven't bottomed out the car or gone to the track in months..
dartonh22
Apr 2, 2012 11:55 AM
nipcup101
Jul 20, 2009 05:17 PM
elpiar
Mar 29, 2005 10:20 AM
fe519
May 19, 2003 07:29 PM
OneThirtyEight
Oct 30, 2001 06:03 PM
