Suspension questions
I have a 97 Civic CX hatchback. I purchased the 5 lug conversion from a ITR, and I have a pair of questions.
1) To install a front sway bar should I use the front LCA from an ITR or a 00 Si?
2) To install a rear sway bar can I use the rear LCA from the ITR or the Civic's stock ones?
Any help is greatly appreciated.
Use the front LCA's that match the swaybar (itr-itr or si-si). Some civics and integras have different ways of mounting the front sway. I'm not sure how the rear sways mount on the 96-2000 civics, but if theyre like the 92-95, don't use the itr rear bar unless you brace the subframe (22mm bars tear out the subframe on 92-95 civics).
SoloSol
Jan 22, 2004 10:23 AM
ej1civic
36
Jul 23, 2003 08:20 AM
