Where do the EVAP hoses go?
Old Nov 3, 2004 | 01:36 PM
McNizzle's Avatar
Default Where do the EVAP hoses go?
I have one vaccum hose that is just dangling from the main evap cannister by the battery and i dont know what it plugs into. does anyone have any pics? I have a skunk2 IM if that makes any difference. Thanks!
Old Nov 3, 2004 | 02:59 PM
smart monkey's Avatar
Default Re: Where do the EVAP hoses go? (Chris M)
that hose goes to the evap purge on the intake man. then a hose from the evap goes onto the intake man
Old Nov 3, 2004 | 05:33 PM
McNizzle's Avatar
Default Re: Where do the EVAP hoses go? (smart monkey)
is there a pic? all of the vaccum nipples already have vaccum hoses on them on intake mani.
Old Nov 3, 2004 | 09:58 PM
sorry no pic but since you have that skunk man it does not have a port for it. you should of drilled and tapped one for it if you want to use it. the car will run ok without it.
Old Nov 3, 2004 | 10:00 PM
McNizzle's Avatar
so the hose is just fine dangling there?
Old Nov 4, 2004 | 07:07 AM
yes but if you want it to be clean looking then cap it off or go the distance and hookup the evap purge.
Old Nov 12, 2004 | 08:16 PM
bleedblue94's Avatar
you dont just leave it hanging there .... spend $3 and buy a " T " and tap the vaccum line from the pcv valve to the manifold.......otherwise you are just allowing your evap system to release fuel vapors in your engine bay (it kinda hot in there) can you say boom boom
Old Nov 13, 2004 | 06:18 PM
si punk's Avatar
Default Re: Where do the EVAP hoses go? (bleedblue94)
how much vapor is actually dispersed out of the hose?? I mean it would take a considerable amount of vapor to ignite...like practically spraying gas into the air.
Old Nov 13, 2004 | 06:47 PM
Default Re: Where do the EVAP hoses go? (si punk)
but why would you even do it when all you have to do is buy a t and tap the pcv hose
Old Nov 14, 2004 | 04:59 AM
McNizzle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bleedblue94 &raquo;</TD></TR><TR><TD CLASS="quote">but why would you even do it when all you have to do is buy a t and tap the pcv hose</TD></TR></TABLE>
true i think ill go with the T. thanks
Old Nov 14, 2004 | 10:29 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris M &raquo;</TD></TR><TR><TD CLASS="quote">true i think ill go with the T. thanks </TD></TR></TABLE>
no prob
Old Nov 15, 2004 | 10:13 AM
si punk's Avatar
yeah I know that, I was just sayin...it's VERY unlikely that it would go "boom boom" heh.
Old Nov 15, 2004 | 10:50 AM
CivicSiRracer69's Avatar
I had that same Q, one goes to the TB and the other is the other line that I dont know where it goes.
Old Nov 15, 2004 | 11:06 AM
b16pwrdeg's Avatar
Default Re: Where do the EVAP hoses go? (CivicSiRracer69)
I though the hose from the EVAP Canister went to the "nipple" on top of the throttle body
gursh d
Aug 21, 2007 08:35 AM
GetawayInMoscow
Jul 25, 2007 08:09 PM
Rubixcu7
15
Jul 11, 2006 02:40 PM
tsjeff
Apr 19, 2005 08:45 PM
