pads squeeling, front or rear?
Old Nov 3, 2004 | 11:20 AM
skunk2eg's Avatar
Default pads squeeling, front or rear?
does the e-brake control the front brakes at all....my brakes are starting to squeel and if i pull the e-brake up slightly it goes away for a bit..
question is could it be my front pads at all or do i need to just replace the rear pads?
Old Nov 3, 2004 | 11:26 AM
edd001's Avatar
Default Re: pads squeeling, front or rear? (skunk2eg)
it could be your pads are low or your pads are stuck in the caliper.
if your pads are not low then remove the pads and clean them up and also clean the caliper and shims.
Old Nov 3, 2004 | 11:30 AM
skunk2eg's Avatar
Default Re: pads squeeling, front or rear? (edd001)
they are fairly new, just replaced the front pads and rotors like 4 months ago..
does the anti-squell compound work well?
Old Nov 3, 2004 | 11:35 AM
edd001's Avatar
dont know. when we put new pads in we clean the shims and put a little copper grease on the back of the pads and the top and bottom of the pads where they sit in the calipers. it dose not take much for the pads to get stuck which is what i think your problem is.
Old Nov 3, 2004 | 11:56 AM
AutoXer's Avatar
Drums or disks? I'm assuming disk since you said rear pads.
The E-brake works the rear brakes, so if by using it the squeal goes away, that's probably where the problem lies.
Old Nov 3, 2004 | 11:58 AM
skunk2eg's Avatar
Default Re: pads squeeling, front or rear? (EX_AutoXer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EX_AutoXer &raquo;</TD></TR><TR><TD CLASS="quote">Drums or disks? I'm assuming disk since you said rear pads.
yeah all wheel disc, i think its the rear brakes
MachAF
Suspension & Brakes
Sep 26, 2009 10:02 AM
Toneman14
Sep 23, 2005 08:29 AM
dman81
Jun 3, 2005 09:03 AM
PatrickGSR94
May 25, 2004 10:18 AM
jester
15
Oct 5, 2003 06:29 AM
