synthetic vs natural
Old Dec 22, 2001 | 01:05 PM
swarsing's Avatar
Default synthetic vs natural
my 95 b18c1 tends to use more oil(about 3/4 0f a quart every 3k)when using synthetic compared to almost none when i use natural,has anyone else expeirenced this ?and what would cause this?THANKS!
Old Dec 22, 2001 | 02:47 PM
speedymon's Avatar
Default Re: synthetic vs natural (swarsing)
I don't know the exact reason but engines are more prone to leaks when you go from natural to synthetic. Especially when you have a high mileage car.
Old Dec 22, 2001 | 03:59 PM
Cow's Avatar
Cow
Default Re: synthetic vs natural (speedymon)
Synthetic oil is thinner and therefore will leak more easily. Older engines are prone to leaking oil because the seals and gaskets begin to wear out. Therefore you'll be filling up more often with synthetic. HTH
Old Dec 22, 2001 | 04:05 PM
MachAF's Avatar
When using natural oil, you get sludge build up that seals certain parts in the engine. When you swtich you syn, the sludge is removed by certain materials in the syn oil. That is why you will usually see oil leaks from switching to syn. Eventually they should go away.
Old Dec 22, 2001 | 04:08 PM
speedymon's Avatar
Default Re: synthetic vs natural (machaf)
I knew that was the reason. I didn't want to say it and be wrong. Then i would get flamed. I'm such a *****! Post ***** that is.
Old Dec 22, 2001 | 05:50 PM
1fastGSR's Avatar
New User
I started using synthetic in my old 96 LS and 00 GSR after my FIRST oil change and never had any problems. Actually, my car uses about 1/4 quart every 3k-4k miles but I think that is OK.
Old Dec 22, 2001 | 05:51 PM
OneThirtyEight's Avatar
Default Re: synthetic vs natural (1fastGSR)
cam-seals and redline= loss of oil
Old Dec 22, 2001 | 09:05 PM
speedymon's Avatar
Default Re: synthetic vs natural (97blackteg)
I need to start checking my oil regularly. I have 80k on the dash.
Old Dec 23, 2001 | 12:35 AM
i have like spots of oil on my fuel rail, intake manifold and hood from oil squirting out of my camseal at high RPM, its annoying.
Old Dec 23, 2001 | 10:48 AM
speedymon's Avatar
damn dude you need to get that checked out. THank fully i don't have much wrong with my car from mods. Previous owner was a ricer.
Old Dec 24, 2001 | 11:18 AM
Erik_Pb_Foot's Avatar
New User
haha, same problem with my cam seal using amsoil 0w-30. i'll be ordering an str once the fresh coat of gasket seal peels off and oil starts leaking again.
92EG8
Nov 1, 2006 06:53 PM
VINtegra90
Apr 18, 2005 03:00 PM
old_school_dohcvtec
Feb 10, 2005 06:03 PM
blackhatch13
Mar 28, 2003 08:01 PM
TypeR01-424
Aug 17, 2001 07:51 AM
