H22 into acura cl
Old Nov 3, 2004 | 10:27 AM
noslude93's Avatar
Default H22 into acura cl
Ok I am trying to fix a swap fora freind.
I fixed pretty much everything I could see wrong.
Its a 99 Acura cl with a obd1 h22, I switched the dizzy wiring over to obd1.
I wired the injector ressister box.. yada yada ...
OK so The problem I am having is , I got the car running really good.
It drives nice, idles nice.
BUT The check engine light stays on all the time . Go and try to check the codes and there is no codes . It just stays solid ?
Any one have any Ideas.
It had codes before that I fixed , now It just does this after I fixed it all ?
Old Nov 3, 2004 | 03:44 PM
noslude93's Avatar
Default Re: H22 into acura cl (noslude93)
nobody knows?
Old Nov 3, 2004 | 06:23 PM
noslude93's Avatar
Has anyone even heard of a problem like this?
Old Nov 3, 2004 | 06:51 PM
PyroProblem's Avatar
Not sure about H series in CL's but on alot of Hondas,keeping the service connector connected keeps the CEL on...(or grounding out somewhere)
Also usually when an ECU has a fault and cant diagnose it,you condemn it because it cant tell you whats wrong with it via codes(code 0)...Hopefully the ecu doesnt have a fault with its own diagnosis ability
Old Nov 4, 2004 | 03:07 PM
noslude93's Avatar
Default Re: H22 into acura cl (PyroProblem)
well the ecu is good because it does the same with other ecu's.
There is not vtec. everything else is the way it should be .
check engine light- no codes
no vtec.
Pulling hair.......
Thank you for your reply. !
Old Nov 5, 2004 | 08:42 PM
sedracer's Avatar
are you sure your running the correct ecu. if it throws no codes and has no vtec that could be your problem. i also no that my OBD1 swapped accord the ecu will not output the codes threw the service connector i have to jump the connector under the dash and the CEL will flash the codes.
Old Nov 7, 2004 | 06:08 PM
noslude93's Avatar
Default Re: H22 into acura cl (sedracer)
I am jumping the one under the glove box. It gave me codes but I fixed them all.
Now this is what I have left.
I was working on it the other day and I think the power wire for the dizzy got grounded out. Now I have no power to the dizzy. I was looking for bad wiring, and I think it some how touched somthing and grounded it out.
Any help would be great .
Thank you
BoostThisMS
Apr 2, 2010 09:48 AM
blu3g
12
Feb 14, 2007 12:47 PM
acclude-vtec
Jan 8, 2006 08:57 AM
