carbon hood that fits a B16
I have a b16 in a 88 CRX HF i also have a inline pro with a tial 38 wg. that comes close to hitting the stock hood. So i want to get a new hood because my old one is trashed what hood fits over the motor. will the VIS JDM hood with the bumb fit or not.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 point 6 »</TD></TR><TR><TD CLASS="quote">to run the JDM hood you need the JDM front end conversion. You can always cut the skeleton of the CF hood, seen it done pleanty of times before.</TD></TR></TABLE>
No you don't, you just buy the SiR hood made to fit with the USDM front. Problem solved.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skunk.Werkz »</TD></TR><TR><TD CLASS="quote">
No you don't, you just buy the SiR hood made to fit with the USDM front. Problem solved.</TD></TR></TABLE>
ViS makes that hood? News to me.
yes they make that hood. Its on back order though I have been waiting for spark racing to get that hood in for 4 weeks now. I'm still waiting patiently....
DEF
DEF
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skunk.Werkz »</TD></TR><TR><TD CLASS="quote">Someone makes it</TD></TR></TABLE>
...and I believe ViS might be one of them...
VIS and Seibom make the SiR cf hood that will clear your setup....
phasenine.com sells them pretty cheap that's where I got one for my friend. I think it was $350. don't remember now though. email them.
thanks for all the help guys i would make one my self but it takes to much time i am sure i might have to do some mods but i work with carbon all the time here are some pic's of work that i have done.
well i don't really go for looks the wheel was made from hand and that was the first one but the wheel does only weight less then 1/2 lb which was the main point in makin it.
the car is a FSAE car it is about 500 lb's has a GSX-R 600 motor in it and is open wheel. they are fun to drive and build every year. i am working on a turbo project this year for the car.
http://www.passwordjdm.com sells the SiR style hood for US front ends. My stock hood is gutted underneath, so rubbing and the hood is hella lighter now. No problems with it unlatching and flying up, even at 125mph
