i need a ecu pin out pic for obd-0
ok every one first i did search but not what i need. im goin to install my a/f gauge (i know it's a light show) and i dont want to run the o2 wire into the engine bay so i need to know which wire is the o2 wire @ the ecu. ive been told it's wire d14 (a thick white wire??) well there are alot of white wires so i need a pic to figure out which pin is d-14? if it matters the car is a std ef that has been wired for zc (so it's si converted?) thanks for any help
There is no way you could of searched and not got the awnser for this,
refer to the swap guide in my sig, there is wiring info for the stock pins,
as far as i know there isnta "D " plug
edit, primary o2 is c16,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowpokesi »</TD></TR><TR><TD CLASS="quote">There is no way you could of searched and not got the awnser for this,
edit, primary o2 is c16, </TD></TR></TABLE> well lets see first off i did do a search i typed in: ecu pinouts and i found 4 recent threads and in the archives i found 93 threads, and i couldnt find out how to figure out how to read the pins (a1,b5c16 and ect) well atleast for a usdm obd-0 all i could find was stuff for v-tec or prelude or obd-1. but thanks anyways for tryin to help
in my swap guide if you scroll down to where that image is, right above it there is a link to a chart with each wire pin out and what they are for, in addition to that in the helms manual that i also host on my site you can find the same information!
sorry man i couldnt get the gauge to work at first but i found out that you have to let it "warm" up and now it does.... so thanks for the help slowpokesi
accordianex
Feb 19, 2006 07:07 AM
spoonzdelsol
Oct 4, 2005 12:40 PM
