vtec control
yup, grab a wire diagram, use the instructions, they are pretty well laid out, and solder. use shrink wrap if possible, and you will be fine. if you doubt your wiring abilities, then you should have someone that knows whats goin on do it. but on a 1-5, its a 2.5 on difficulty. i think.
Not that hard just follow the directions and double check everything that you do. also if you happen to have a SOHC use the diagram from the B16 of that year model.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by props_honda85 »</TD></TR><TR><TD CLASS="quote">Not that hard just follow the directions and double check everything that you do. also if you happen to have a SOHC use the diagram from the B16 of that year model.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mystery »</TD></TR><TR><TD CLASS="quote">is sodering better than crimping the wires
um, yeah. soldering is the best way to splice. hands down.
hondaacura94
Dec 12, 2003 04:29 PM
