Barely failed WI emissions, damn HCs
Old Nov 3, 2004 | 05:35 AM
EFz6er's Avatar
Default Barely failed WI emissions, damn HCs
Well I passed on everything except the HCs which the limit is 0.8000 and I had 1.0005. What causes the HC to be higher and what can I do to lower this for a enuf time to pass and move on. I dont want to dump any money into this car if not needed.
Heres my set-up: D16z6, PM7 ecu obd0, mpfi, intake, custom catback and there is a little exhaust leak before the cat I think and I have no CELs.
I ignition timing might be off could that do anything to effect the HC count?
Please give me some ideas, I have to pass emissions becuase my tag is up at the end of the month
Old Nov 3, 2004 | 05:48 AM
crx_88_si's Avatar
pm7 = zc ecu right?
try a pm6.
HC = unburnt fuel = you're runnin rich. probably cuz of the fuel maps of the ZC ecu.
Old Nov 3, 2004 | 06:01 AM
EFz6er's Avatar
Default Re: (crx_88_si)
I dont have a pm6 and dont really want to spend the $50 on an ecu...I have a pm8 that would lean it up quite a bit. Would I fail if its not getting enuf fuel or a way to make the gas burn better???
I have heard of people putting rubbing alcohol in their gas. Anyone ever heard this???
Old Nov 3, 2004 | 06:32 AM
crx_88_si's Avatar
Default Re: (EFz6er)
rubbing alcohol would basically give it a higher octane rating. so dont do that. it'll be worse.
the pm8 MIGHT be ok.. but u will get a cel (lack of EGR).. im not sure if they'll even check it w/ the pm8 installed.
i bought a spare pm6 for $15shipped.
look for an 88-89 ecu (usually cheaper)
Old Nov 3, 2004 | 07:15 AM
4drEF's Avatar
Keyboard Humorist
Default Re: Barely failed WI emissions, damn HCs (EFz6er)
Your ignition timing would throw off the HC's.
Can you post your other test results?
HC's and CO's usually go hand in hand, but if the CO's were pretty low then it changes the ball game.
What did you do as far as tune up goes before the test?
Chang out the plugs, wires, distributor cap... etc??!??
Do you have an adjustable fuel pressure regulator?
Old Nov 3, 2004 | 07:24 AM
EFz6er's Avatar
Default Re: Barely failed WI emissions, damn HCs (4drEF)
Heres the full test results:
HC-----------1.0005 LIMIT----0.8000>>>FAILED
CO-----------12.5252 LIMIT----15.0000>>>PASSED
NOx----------0.5902 LIMIT----2.0000>>>PASSED
My gas cap failed too LOL
I did nothing but I did look at the plugs and I knew my car was running rich becuase of the PM7 on the z6.
I think my ignition timing might be off beciase the original owner might have had a shot of nitrious, but I havent had time to get it checked. Pretty much the car is the same as when I bought it except for an obvious oil change.
Old Nov 3, 2004 | 08:36 AM
drdisco69's Avatar
Hydrocarbons can rise due to retarded ignition timing. Advance it to stock, or a litte more if you need to, and give it a shot. I've gotten my cars to pass, and they are very fucked up in the emissions dept.
We got my 85 Corolla from 1100 HC to 160 HC. Just takes some tweaking.
Old Nov 3, 2004 | 10:55 AM
deftones0817's Avatar
Default Re: Barely failed WI emissions, damn HCs (drdisco69)
yeah adjust dizzy and try again. YOu should pass easy.
DEF
Old Nov 3, 2004 | 11:14 AM
EFz6er's Avatar
Default Re: Barely failed WI emissions, damn HCs (deftones0817)
Yeah my bro is going to do it on Thurs so I'll let you all know whats up with the results. Thanks for your help guys
Old Nov 5, 2004 | 06:03 AM
EFz6er's Avatar
Well I advanced the ignition timing and I noticed that the dizzy is only held on by one bolt. Is that becuase its an obd0 dizzy on the z6? If I were to convert to obd1 would I have to get a obd1 dizzy?
Im going to run it thru this afternoon and hopefully I'll pass this time. Now that its advanced the car seems more responsive and, for lack of better words, its peppy. I like
PetersonJ39
May 9, 2011 06:07 PM
vtc-gn2
Mar 16, 2006 02:48 PM
FourthGenHatch
Apr 19, 2004 05:55 PM
FourthGenHatch
Feb 26, 2004 07:58 PM
JohnysZC
Dec 19, 2001 01:24 PM
