Possible Tranny Fix$$$? (b16)
Old Nov 3, 2004 | 03:36 AM
1SlowSi's Avatar
Default Possible Tranny Fix$$$? (b16)
Hey guys whats goin on. A while back, i wasnt thinking and jammed it into reverse sitting still without pressing down the clutch. It grinded like a ****. Now when i start off in first gear i hear what sounds like broken pieces of metal inside. Thats the best i can descirbe it. Its very faint but its there. Its more noticable when you are barely rolling back and start to engage in 1st. what i want to know is maybe possibilities, and how much it would cost for someone to open the tranny up and take a look at what may be wrong with it. I drive around normal daily, no problems what so ever. you know what they say. If it aint broke dont fix it. Help me out here. B16 Hydro from 99Si.
Additional Problem: When my shifter is in gear, doesnt matter if its 1st-5th, it has ALOT of play. I can move it at least an inch 1/2 left and right. yeah so a total of 3" of play. It has to do with the link on the tranny. Any ideas to get rid of that?
Old Nov 3, 2004 | 08:45 AM
drdisco69's Avatar
Default Re: Possible Tranny Fix$$$? (1SlowSi)
You may have damaged the reverse idler gear. I don't know what it'll cost to get looked at.
For the shifter, the play can be caused by either the linkage that bolts to the shifter being loose, or more common for older cars, the shifter bushing that the shifter sits in is worn. That's like $8, and simple to replace. Check if the linkage is loose, it doesn't have to be very tight, otherwise it is difficult to shift.
Old Nov 7, 2004 | 12:05 AM
1SlowSi's Avatar
Default Re: Possible Tranny Fix$$$? (drdisco69)
As for the shifter bushings, i have already replaced them with the Energy Suspension's. I have tightened the bolt that the shifter connecs to and yeah it makes it harder to shift. All the play looks like its coming from the link to the tranny itself. I have a 99, i mean my car shifts, im not gonna rip anything apart to fix it. reverse idler gear... how much we lookin at? $$$ thanks.
Old Nov 7, 2004 | 07:55 AM
SkRiBLaH's Avatar
reverse idler gear is the simplest thing to fix. if it were me id take one day , open the tranny and replace the reverse idler gear.
its that simple.
Old Nov 8, 2004 | 07:11 AM
1SlowSi's Avatar
Default Re: Possible Tranny Fix$$$? (SkRiBLaH)
Ya think thats what it could be? how much does that go for??
Old Nov 8, 2004 | 09:00 AM
murtnabila's Avatar
When I'm in 1st, 2nd, and 3rd I get a metal grinding sound and it's my bearings.
Old Nov 9, 2004 | 01:12 AM
1SlowSi's Avatar
Default Re: Possible Tranny Fix$$$? (murtnabila)
Dont they make tranny overhaul kits? Just wanna replace everything inside and start fresh. haha.
Old Nov 9, 2004 | 08:47 PM
cruz78727's Avatar
depend on if you do it ur self or pay a pro to do it for u. everyone says its easy but you also have 2 know what ur looking at when ur in there. simple if u dont know dont try it or u could make thing worse!
Old Nov 9, 2004 | 09:30 PM
1SlowSi's Avatar
Default Re: Possible Tranny Fix$$$? (cruz78727)
Ill just leave it all alone. If it aint broke dont try and fix it. I can shift fine, and drive around with no problems. Just gives me a reason to someday buy a GSR tranny.
Old Nov 10, 2004 | 11:08 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
i'm in st marys GA above jax. i do a lot of b series tranny rebuild/repair. pm me for my contact number and estimate. i can come to j'ville and drop and open your tranny if you really wanted.
Old Nov 11, 2004 | 01:46 AM
1SlowSi's Avatar
Default Re: Possible Tranny Fix$$$? (not so civic)
I appreciate the offer man. I actually live in fernandina beach.. even closer! haha. ill get up with you sometime.. when i get back becuase im deployed right now.
00BlackBeauty
Mar 22, 2010 11:16 PM
vtec25
Feb 1, 2006 11:53 PM
B16X
Aug 11, 2004 06:35 AM
LoSt is BlaCk
30
Nov 12, 2003 01:35 PM
keebler65
Mar 26, 2003 04:39 PM
