H22 TB on D series IM.
Old Nov 2, 2004 | 11:18 PM
Root79's Avatar
Default H22 TB on D series IM.
Did research in this way. Have the D16Z6 manifold and some TBies in the shop. Then I find out that H22A2 TB perfectly fit on Z6, Y8 intake manifolds. All water chanels fit too. Only difference is in bore. Z6 and Y8 must be resised for h22 TB inside diameter. Same time the H22 can be resised too for beter air flow, then IM can be modifided.
I did not mesure the stock diameters of TB and IM, try to do that today.
Old Nov 3, 2004 | 03:44 AM
civic-4-ges's Avatar
Default Re: H22 TB on D series IM. (Root79)
Pretty much common knowledge.
Don't waste your time measure the tb, you can probably take a second and search for "TB Sizes" and will tell you the size oif the TB in questions
BTW..damn near all Honda Automotive throttle bodies are interchangeable
Old Nov 3, 2004 | 04:31 AM
Root79's Avatar
Default Re: H22 TB on D series IM. (civic-4-ges)
Interesting, somebody ever instaled H22 TB on sohc IM. Did some dynos?
em1_mark
Feb 9, 2005 05:56 AM
5thGenLX
Jan 6, 2005 01:54 PM
Jdmbsixteen
Oct 16, 2003 11:05 AM
Ricey McRicerton
Nov 21, 2002 03:36 PM
