what type of engine
engine - F22B2 - as far as h22 head, probably not. since you know about it i'm assuming you know that you pretty much need an h22 to start out with for all the misc. parts it will require. plus, the main reason people do this is for turbocharger applications.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by momstaxi »</TD></TR><TR><TD CLASS="quote">engine - F22B2 - as far as h22 head, probably not. since you know about it i'm assuming you know that you pretty much need an h22 to start out with for all the misc. parts it will require. plus, the main reason people do this is for turbocharger applications. </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by luckecharm2004 »</TD></TR><TR><TD CLASS="quote">what type of engine is in a stock 96 accord ..i know it is a non v tec..would it be the f 22? and if so,,is it worth it to do a mini me onto it with a h 22 head? </TD></TR></TABLE>
do you guys know what you are talking about?... i don't think so...his F22 is single is it not? and an H22 is DUAL. 1+2 DOES NOT equal mini me. turbocharger apps? it's not worth it IMO. get an H22.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Advan06 »</TD></TR><TR><TD CLASS="quote">
get an H22.</TD></TR></TABLE>
i think thats all that needs to be said. if its in u'r budget anyway.
do you guys know what you are talking about?... i don't think so...his F22 is single is it not? and an H22 is DUAL. 1+2 DOES NOT equal mini me. turbocharger apps? it's not worth it IMO. get an H22.</TD></TR></TABLE>
yes, i do know. yes f22 is single cam. yes h22 is dual cam. yes they can be mated together(hseries head, fseries block. turbo situation because of iron sleeves and low compression ratio with stock pistons.
