My brothers d15 non v-tec del-so idle jumps....
Old Nov 2, 2004 | 06:39 PM
boiwitwhitehond's Avatar
Default My brothers d15 non v-tec del-so idle jumps....
on a cold start or normal start the car will start and idle just fine...but after a lil while of driving and the engine warms up...when my brother puts the car back in park(auto tranny)..the idle jumps from 1k - 1.5k ..it just jumps and jumps and jumps...any idea what may be the problem?..
we have already cleaned out the mesh in the IAVC( however u spell it)...thanks for your help!
Old Nov 2, 2004 | 06:40 PM
sohcvtec1995's Avatar
Default Re: My brothers d15 non v-tec del-so idle jumps.... (boiwitwhitehond)
Vacum leak?
Old Nov 3, 2004 | 03:05 AM
Default Re: My brothers d15 non v-tec del-so idle jumps.... (sohcvtec1995)
bump!
Old Nov 3, 2004 | 06:08 PM
please help
Old Nov 3, 2004 | 07:04 PM
Tad's Avatar
Tad
heh, I have the same thing on my car,
but i just put on a jrsc,
basically chances are you have a vacuum leak somewhere, like a gasket somewhere( Intake mani or throttle body gaskets are often causes)
or it could just be a vacuum hose popped off somewhere, or has a tear in it!
check for hoses first.
Old Nov 4, 2004 | 06:40 AM
Default Re: (Tad)
bumpp..gonna check the lines in a lil bit..anyone else out there might think they know what it is?
Old Nov 4, 2004 | 07:50 AM
Falqon's Avatar
Take off the intake piping when it's doing the wierd idle, and put your hand over the lower hole in the left just before the butterfly valve. It's probably sucking in air. If so
take apart the IATV, it's under the throttle body, it's got a coolant hose running to it, like 3 10mm (I think) bolts, and no electrical connection. You unscrew the 2 philps screws on the end, feel that big white plunger (it's probably loose) then you screw it back in with like 2 screwdrivers as far as it'll go.
Excusetoboost
Sep 1, 2011 07:40 PM
luv2boost
Jun 2, 2008 06:33 PM
virusiidx
Jan 18, 2005 07:21 AM
out_of_order
Aug 5, 2004 12:28 PM
Hnda_Crx_Man
Apr 1, 2002 11:28 PM
