need new si brakes, what will swap?
Old Nov 2, 2004 | 06:38 PM
stealth89hatch's Avatar
Default need new si brakes, what will swap?
i just bought a 92 si (non-abs) and one of the rear calipers is shot. none of the local junkyards seem to have the right part, so i'm wondering what will work from other hondas in its place. its already a disc brake, so i'm not looking to do the swap as most people are, but will the accord or something brakes fot? i'm not sure that there are any integras lying around, although it looks like they will fit. i really just need something to get it past inspection.
thanks
Old Nov 2, 2004 | 06:57 PM
pdiggitydogg's Avatar
just a rear caliper?
any civic/integra/delsol rear caliper will work........just like a trailing arm
Old Nov 2, 2004 | 07:39 PM
Default Re: (pdiggitydogg)
thanks for the reply, yes, just the caliper and rotor.
are all those options same size? (just as long as they're non-abs right?)
and i assume this means the accord wont fit?
Old Nov 2, 2004 | 07:47 PM
abs or not doesnt matter
it doesnt work that way
Old Nov 2, 2004 | 07:59 PM
i was under the impression that the abs rotors were larger. so if i got 1 abs rotor and had 1 stock non-abs rotor there would be an uneven brake balence. but i suppose 2 abs rotor would be fine
Old Nov 3, 2004 | 05:29 PM
Default Re: need new si brakes, what will swap? (stealth89hatch)
i've found cross drilled rotors for sale, but the application says:
01-02 Honda Civic all models
99-00 Honda Civic EX and Si
96-98 Honda Civic EX, Si and SiR 2 Door Coupe
94-95 Honda Civic 4 door EX w/ ABS, 3 door Si w/ ABS and 2 door EX with ABS
92-93 Honda Civic 4 door EX
94-97 Honda Del Sol with ABS
90-01 Acura Integra except Type R
and the 92 civic si hatch is not on there. is it actually true that the rotors are not swappable? or is it just an incomplete list?
Old Nov 4, 2004 | 06:29 AM
bump for question above
Old Nov 4, 2004 | 06:33 AM
BigPlansNoMoney's Avatar
Anybody correct me if I am wrong, but typically EG Civics, DC2 Integras, and del Sols/CRXs share many of the same parts, because I am pretty sure the Integra and Civic share the exact same chassis (not sure on the del Sol/CRX)...
EJ6_PickUpStix
12
Jun 23, 2021 11:44 AM
Aztex_Slingshot
Aug 10, 2009 08:07 AM
kit50si
13
Nov 18, 2006 06:06 AM
LilCivic04
Suspension & Brakes
Feb 17, 2005 09:05 AM
RickChew
Mar 4, 2003 07:29 AM
