My Cf hood won't latch!!! HELP MEE!!!!
Old Nov 2, 2004 | 03:48 PM
initialvtec's Avatar
Default My Cf hood won't latch!!! HELP MEE!!!!
I just bought a bknw cf hood from a local. I bolted up all the hinges and everything, but when i go to close the hood the safety latch works, but the second latch won't lock it? I even tried leaving the hinges loose, so i can move it forward and back. It looks like the latch goes right down the middle and is even? No matter how hard i push or what angle, it won't latch! I tried adjusting the latch locking mechanism on the radiator support and i made it the highest, and it still won't latch? I measured the latch of the stock hood and it was around 1 3/4" while the bodykits nw hood was about 1" 3/8", but i don't think that should matter much? Any help would be great guys... thanks!
Old Nov 2, 2004 | 04:04 PM
jbell's Avatar
Default Re: My Cf hood won't latch!!! HELP MEE!!!! (initialvtec)
hood
pins.
Old Nov 9, 2004 | 12:57 PM
Default Re: My Cf hood won't latch!!! HELP MEE!!!! (jbell)
i am running hood pins, i still want the latch to work
Old Nov 9, 2004 | 01:21 PM
rusted_eyes's Avatar
Lift hood all the way up and slam shut works every time!
Old Nov 9, 2004 | 01:22 PM
B_CRUZ!'s Avatar
adjust the latch(on the rad support.). there should be 2 or 3 10mm holding it down. loosen it and raise up the latch. I did this with my old set up.
Old Nov 9, 2004 | 01:33 PM
Default Re: My Cf hood won't latch!!! HELP MEE!!!! (b_cruz.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b_cruz. &raquo;</TD></TR><TR><TD CLASS="quote">adjust the latch(on the rad support.). there should be 2 or 3 10mm holding it down. loosen it and raise up the latch. I did this with my old set up. </TD></TR></TABLE>
i did, still wont latch.
Old Nov 9, 2004 | 01:38 PM
B_CRUZ!'s Avatar
so you raised it to the highest setting and it wouldn't latch?
Old Nov 9, 2004 | 01:39 PM
yea
Old Nov 9, 2004 | 01:48 PM
EJ6_Hatch's Avatar
your **** is fucked
Old Nov 9, 2004 | 01:51 PM
gabebauman's Avatar
Are the rubber bump stops (just above headlights on the frame) screwed down all the way?...maybe remove them temporarily to see.
Old Nov 9, 2004 | 02:01 PM
Default Re: My Cf hood won't latch!!! HELP MEE!!!! (gabebauman)
yep i compeletly removed them and tried the latch, still no lock.
Old Nov 9, 2004 | 02:03 PM
ekx4's Avatar
throw away the hood.
Old Nov 9, 2004 | 02:33 PM
H8 O ATE's Avatar
some times the actual hook on the assembly gets bent forward from tryin to close it when it is mis-aligned, close the hood on the latch and see where it is hitting. then align it so it doesn't hit
leono
Oct 12, 2005 08:06 PM
initialvtec
Audio / Security / Video
Nov 17, 2004 10:04 AM
initialvtec
Nov 9, 2004 07:19 PM
93HatchCali
86
Nov 25, 2003 08:33 AM
sicklexus1
May 14, 2003 08:35 PM
