Cf hood latch won't latch!
Old 11-09-2004, 01:02 PM
initialvtec's Avatar
Default Cf hood latch won't latch!
I just bought a bknw cf hood from a local. I bolted up all the hinges and everything, but when i go to close the hood the safety latch works, but the second latch won't lock it? I even tried leaving the hinges loose, so i can move it forward and back. It looks like the latch goes right down the middle and is even? No matter how hard i push or what angle, it won't latch! I tried adjusting the latch locking mechanism on the radiator support and i made it the highest, and it still won't latch? I measured the latch of the stock hood and it was around 1 3/4" while the bodykits nw hood was about 1" 3/8", but i don't think that should matter much? Any help would be great guys... thanks!
btw, i'm running hood pins for now.. but i would still like the latch to work.
Old 11-09-2004, 08:41 PM
fcm
Old Fart
fcm's Avatar
Default Re: Cf hood latch won't latch! (initialvtec)
Is the latch working? can you latch it with a screwdriver? or is the hood release cable binding? 94
Old 11-10-2004, 03:23 PM
EM2Civic's Avatar
I had the same problem with my hood what I did was just put a good set off hood pins. You mean it locks but doesn't lock fully right? Like primary lock and secondary lock scenario sorta?
Old 11-10-2004, 05:59 PM
EBP_SI's Avatar
not sure if it'll work for the hood you've got but when i put a friend's hood on his car for him, i had the same problem so i put washers between the hood and the latch. been working since the summer.
Old 11-10-2004, 08:11 PM
93civicEX's Avatar
take off the hood rubber stops. They are like rubber screw's. take those out and you won't have a problem
Old 11-17-2004, 10:04 AM
hellmeroma's Avatar
I had the same problem with my integra. There's a little box looking thing on the cable that runs to the latch, it might be stuck. It's right next to the latch in the opening on the left. Try sliding it to the right, and then latching your hood. That was my problem.
froogle29
Audio / Security / Video
09-11-2009 10:32 PM
leono
10-12-2005 08:06 PM
initialvtec
11-09-2004 07:19 PM
initialvtec
11-09-2004 02:33 PM
Quick Reply: Cf hood latch won't latch!
