HELP! Timing Off??? belt? cam?
Old Nov 2, 2004 | 02:37 PM
Dankness's Avatar
Default HELP! Timing Off??? belt? cam?
Hello, I'm really new to this but it seems like you guys know what you're talking about on here for the most part. Anyway I have a 00 Accord with the 4cyl 2.3l ulev vtec. Its the F23. Anyway, i had the engine rebuilt a while ago and ever since the car has been a bit boggy. I bought an fmax turbo for it and I wanted to make sure everything was up to par before i had it installed. I had it dyno tested and came to find out that it is only putting out 108hp!!!! What the hell is going on??? They seem to think that its the timing belt, that maybe the people that rebuilt my engine didn't line it up correct, or set the cam, or possibly even the distributor. The only mods thus far on this car are: dc headers, hks dragger (dual) exhaust, aem v2 intake, and vafc2. car runs and sounds perfect. I have the money to spend on getting this thing fixed but i just want it done now!!! plz help me out here!!
Old Nov 2, 2004 | 04:19 PM
TOAB's Avatar
Default Re: HELP! Timing Off??? belt? cam? (Dankness)
if it "runs and sounds perfect" your timing isnt off...
Old Nov 2, 2004 | 05:51 PM
Dankness's Avatar
Default Re: HELP! Timing Off??? belt? cam? (TOAB)
Well, i know thats what i thought. In addition the check engine light didn't come on ethier, could it be just a little off? could it be my compression? the car should be putting out at LEAST 150hp
Old Nov 2, 2004 | 09:43 PM
momstaxi's Avatar
yes, thats is definatley a possibility. yes i had a motor that had engine timing off, and yes it sounded fine and it ran ok around town. after experiecing it fall flat on its face at 6000 i decieded something was wrong. after investigating it was my timing was off by 2 teeth.
Old Nov 3, 2004 | 04:50 AM
Dankness's Avatar
Default Re: HELP! Timing Off??? belt? cam? (momstaxi)
Yea well the guys at my dyno shop are pretty convinced that its the timing, I just wanna be sure so that i'm not dishing out $90 an hr for them to take my engine appart only to find that its something else......
Old Nov 3, 2004 | 04:54 AM
Dankness's Avatar
oh yea, did you have your car dyno tested after u got the timing set right? did it run a lot better, more power? i'm sure it did... but it seems like 70hp is a lot to loose if the timing is only off a little bit....
egchico
Dec 19, 2014 02:14 PM
Bryant_novtec
Jan 13, 2014 01:09 PM
Mike1486
Sep 11, 2004 10:57 PM
m3ster
Dec 14, 2003 04:59 PM
flyrod
Aug 14, 2002 06:38 PM
