windows won't go up. Y?
hey hi you guys doing? Its not that serious but I would like to fix it...cuz its gettin cold. My back windows in my accord 90, won't go up all the way. There's bout an inch on both back windows that won't go up. Could it be the motor. I don't know, I hear the motor workin but before it went out, the windows would go almost all the way up and then stop and I had to move it up with my hands.... I don't know I need help please.... thx....!
yeah the motors are most likely bad. take your door panel off and you can see the if there is a kink in the line if not then the motor is definately bad. But bright side is they arent that expensive and are an easy fix. only 3 bolts holdin it in!!
take your doors apart make sure that weather stripping/lining crap isnt crossed over the rails at any point. that was the problem with my 5th gen.
if the motor is providing good power all the way up until that point, or if it start having to work hard as it nears that point id tear the door apart to check.
streetlights
Dec 5, 2008 10:06 AM
JamesQ
May 25, 2005 02:34 PM
