Advise on fixing head gasket problem so I can document for others too.
Need advise on doing a head gasket change. By the way, I plan to do a complete write up after I am done so some poor soul can do it too. I did a write up on replacing my timing belt, water pump, crank & cam shaft seals that has helped plenty of others. Please help me with this project.
I have a 1996 civic ex with D16Y8 engine 83K miles I just bought. Turns out there is a head gasket problem.
First, has anyone done a write up? Any links to help me with the research?
Using a helms manual, it appears I have to remove the distributor assemble from the head. I am concerned how to put it back on and synchronizing with the engine. Anything I need to do before hand? I don't know much about distributor assembly.
After I get the head off, do I just clean the head and engine block and replace the head gasket? I was told to have the head inspected first. If so, how much should I expect to pay for gasket and inspection? How much should I expect to pay for this entire project?
Last, should the vtec soleniod gasket be replaced?
Any advise or tips would be appreciated.
Thank you
Thank you
LSteggyguy
20
Dec 2, 2017 04:49 PM
headrec*
Nov 16, 2007 06:40 PM
