Clusters Pic
Old Nov 2, 2004 | 08:01 AM
Mach69's Avatar
Default Clusters Pic
Since the thread about the 88-89 vs 90-91 thread did not have a picture of a 90-91 cluster with a tach, it had a picture only of a cluster without the tach. So I was wondering, is this a picture of a 90-91 cluter with a tach? I think it is, it looks rounded.
Old Nov 2, 2004 | 08:03 AM
92integra_gs's Avatar
yea definitely the temp and gas gauge are further apart...
Old Nov 2, 2004 | 08:10 AM
Targa250R's Avatar
be professional
Default Re: Clusters Pic (Mach69)
Yes, that is a '90-91 cluster, with a '90-91 Civic "hood" on it. The top edge on '90-91 CRX cluster hoods is more round.
Old Nov 2, 2004 | 08:11 AM
DocSean's Avatar
Default Re: (92integra_gs)
How difficult is it to swap in the 90-91 bezel and gauges into an 88-89 rex?
Old Nov 2, 2004 | 08:12 AM
highhopes's Avatar
I concur....
I have the exact same cluster in my 90 si hatch, and a different one in my 89
Differences:
Red line is solid not dashed
Gas and temp gauges are farther apart
two vertical lines in between gauges
Old Nov 2, 2004 | 08:13 AM
Targa250R's Avatar
be professional
Default Re: (spankjelly)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spankjelly &raquo;</TD></TR><TR><TD CLASS="quote">How difficult is it to swap in the 90-91 bezel and gauges into an 88-89 rex?</TD></TR></TABLE>
It's not too hard - but does take a little wiring work.
A search should turn up the information you're looking for.
Old Nov 2, 2004 | 08:31 AM
d15civ's Avatar
Default Re: (Targa250R)
im guessing there's a difference in clusters, because on mine it has
UNLEADED FUEL ONLY,
but above it, it has the same thing, but in french
mine doesnt have the yellow '55'
i dont have the two vertical lines in between the gas/temp
and i dnt have the vertical red light on the bottom where all the light indicator things are...
other than that, its the same.. and mine is for 90-91
so which cluster do i have.. im confused.
PLUS, mach69, have you realized that u have ur dim/defrost switches, and ur hazard switchs upside down
Old Nov 2, 2004 | 08:38 AM
Targa250R's Avatar
be professional
Default Re: (d15civ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d15civ &raquo;</TD></TR><TR><TD CLASS="quote">im guessing there's a difference in clusters, because on mine it has
UNLEADED FUEL ONLY,
so which cluster do i have.. im confused.</TD></TR></TABLE>
A Canadian one The cluster pictured is USDM.
Old Nov 2, 2004 | 08:40 AM
d15civ's Avatar
neat,
the usdm clusters look nicer
Old Nov 2, 2004 | 10:22 AM
kim_2_da_chee's Avatar
why is '55' marked in yellow?
Old Nov 2, 2004 | 12:37 PM
90civichbsi's Avatar
Default Re: (kim_2_da_chee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kim_2_da_chee &raquo;</TD></TR><TR><TD CLASS="quote">why is '55' marked in yellow?</TD></TR></TABLE>
here in the US back in 1990 highway speed limits were 55mph... so they make it clear on the spedometer where 55 is
1991CIVICHATCH
Nov 15, 2013 02:45 AM
Ldo
Jun 6, 2008 08:13 AM
dephtone
Aug 12, 2005 06:08 PM
IamVtec
14
Feb 25, 2003 04:54 PM
shotty
Jul 28, 2002 08:06 AM
