valve adjustment?
Old Nov 2, 2004 | 07:50 AM
urgonnalearn2's Avatar
Default valve adjustment?
What lobes do you check on a valve adjustment and arent the non vtec lobes on aftermarket cams and factory cams the same spec.???
Old Nov 2, 2004 | 08:57 AM
Default Re: valve adjustment? (urgonnalearn2)
bump
Old Nov 2, 2004 | 09:05 AM
EX-T's Avatar
you don't check the lobes. you check the lash between the rocker arm and keeper.
Old Nov 2, 2004 | 10:59 AM
Default Re: valve adjustment? (DSeriesBKilla)
I thought it was the rocker arm and cam??
Old Nov 2, 2004 | 01:43 PM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by urgonnalearn2 &raquo;</TD></TR><TR><TD CLASS="quote">I thought it was the rocker arm and cam??</TD></TR></TABLE>YES. But I think for SOHC you measure at the valve.
Old Nov 2, 2004 | 04:51 PM
drdisco69's Avatar
Default Re: valve adjustment? (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">I think for SOHC you measure at the valve.
For single cam the feeler goes between the rocker arm and the valve. For dual cam it goes between the cam and the rocker arm.
krazeenoy
May 19, 2007 04:50 PM
SLOAZZ95
Sep 14, 2004 11:39 AM
311
Jul 12, 2004 09:35 AM
1_bad_EF
14
Jul 5, 2003 04:06 PM
95gsr
Apr 8, 2003 07:20 AM
