code 43 fuel problem!!
Old Nov 2, 2004 | 06:16 AM
dcsportsciv's Avatar
Default code 43 fuel problem!!
yesterday my car was idling and then just all of a sudden threw code 43 and it says fuel supply system. defective or malfunctioning fuel supply system. so what could be causing this?
Old Nov 2, 2004 | 01:10 PM
Default Re: code 43 fuel problem!! (dcsportsciv)
bump, i really need some imput
Old Nov 2, 2004 | 01:13 PM
Ketone's Avatar
try fixing your 02 sensor first. Most people fix it, and this code will go away. I have this problem, and the 02 sensor unfortunately was not the culprit for me, but hopefully for you that is all it is.
Old Nov 2, 2004 | 07:33 PM
Default Re: code 43 fuel problem!! (Ketone)
thank you, i think i remember that happening to me as well at one point. ill take a look at it
Old Nov 2, 2004 | 07:40 PM
TTM's Avatar
TTM
I was messing with the O2 sensor a while ago on my nissan stanza, and started it when it was off.. it threw it into safe mode and wouldnt rev past 4500rpms
Old Nov 2, 2004 | 08:12 PM
Default Re: (TTM)
would this cause me to lean out in number 2 and 3 cylinders?
Old Nov 2, 2004 | 08:19 PM
killer6993's Avatar
Default Re: (dcsportsciv)
I am having the same problem. If you get a fix or if I do post here...
Old Nov 2, 2004 | 08:44 PM
Default Re: (killer6993)
well i fixed my O2 wires tonight, hopefully it does the trick, ill drive it tomorrow and let you know how its doing. One question, are you also leaning out on #2 and 3 also?
Old Nov 3, 2004 | 05:14 PM
so i drove my car today and it seems better, my air/fuel guage wasnt reading lean anymore and the code hasnt gone on yet.
Old Nov 12, 2004 | 04:48 PM
slow94coupe's Avatar
what do you mean fix the wires? i have a code 1 and 43 so im guessing its my oxygen sensor?
Old Nov 12, 2004 | 06:44 PM
f1z1c's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dcsportsciv &raquo;</TD></TR><TR><TD CLASS="quote">would this cause me to lean out in number 2 and 3 cylinders?</TD></TR></TABLE>
Check Gas cap (for pressure seal), gas pump, gas filter, clogged injectors, running on low fuel level? Over advanced ingnition? Octane too high? Spark plug temp out of range?
crxpwr1
Sep 9, 2008 03:27 AM
lance_ecl
Mar 6, 2008 08:27 PM
jdm206
13
Dec 6, 2007 01:06 AM
PhilStubbs
Jan 22, 2005 11:20 AM
alberto.garrido
Jul 27, 2004 09:33 AM
