EG power window wiring harness
hey guys i did a search and couldn't find anything ...
ok.. so ive got an EG civic breeze... i dunno if breezes came out in the US, but its the 1.3 singe carbi EG with NO options at all..
namely no power windows..
However, i have done a b16a conversion using JDM SIR engine etc and of course the JDM eg6 wiring loom
Im goin to buy all the nessesary parts from wreckers to do power window conversion.... now i just need to know this..
Im not big on electricals so bear with me...
Will i need a power window wiring harness? Im not sure how it all plugs in (gonna get help installing it)
I have an eg6 loom does this mean i dont? or does this not even come into play?
Because the Breezes dont have power windows or mirrors, does this mean the original loom wouldn't be compatible with the windows installation and i would need a harness?
But because i have an eg6 loom, which originally had power windows, mirrors etc, do i not need one?
And just to double check, wat parts do i need to get from the wreckers to make sure i got everything ?
Im buyin Si or Vti door trims..
He said hed give me *everything i need*, but i dont trust him so id like to double check with someone on here who knows.. apart from the trims... i need.... :
Relay, Switches (part of the trim? yes/no? ), motor ... ? thx alot!
you need the motors and regulators should all be one piece anyway. The switches, relay, and the harness that plugs into the back of the fuse box. If you can get the door wiring harness that will save you a lot of time wiring. you need to put a couple extra fuses into the fuse box i think there is one for each window. run new wires from the harness by the fuse box to each door. A little tip just do all the wiring and make sure the motor works before you try installing everything.
thx monicle but ur pictures are a little vauge no offence.. i just find it a little hard to follow..
mc - thx for the reply very helpful. Will it just plug into my loom? or will i need to splice wires? thanx
by the way .... does it matter what model i get the power window parts from
here in Australia we have
EG3 Breeze
EG4 GL, GLi
EG5 SI
EG5 VTI
all have power windows and mirrors.. except the breeze..
Breeze is 1.3 single carbi (NO POWER OPTIONS)
GL is 1.5 twin carbi , GL is 1.5 EFI
SI is d16 DOHC non-vtec
and VTI is d16 SOHC vtec
if im using an EG6 loom, will any of these fit ? thnx
Modified by Sir_JDM at 3:35 PM 11/2/2004
EG3 Breeze
EG4 GL, GLi
EG5 SI
EG5 VTI
You will probably need to do some wire splicing I know I did. I would probably just get them from wich ever model is the same type of car (4 door, 3 door, 2 door) then everything should fit
limerence
Mar 13, 2008 04:18 PM
HeavyFoot_Tony
Dec 18, 2007 10:15 PM
lakaspeed
Feb 9, 2007 03:09 PM
95excoupe
Mar 9, 2003 12:04 AM
