del Sol door removal
Old Nov 1, 2004 | 09:06 PM
CaptivaBlue's Avatar
Default del Sol door removal
I need (want) to take my door off so I can bring it into the barracks to work on the locking mechanism tommorow after the Honda dealer gets my part. Are there any special concerns? Is it as straightforward as it looks? My concern is that I take the door off and when I go bolt it back on it will sag badly (viva la Camaro!).
Old Nov 1, 2004 | 09:37 PM
civictildeath's Avatar
Default Re: del Sol door removal (CaptivaBlue)
doors are a pain to line up again so good luck
Old Nov 1, 2004 | 10:36 PM
Default Re: del Sol door removal (civictildeath)
when you say line up, you mean line up the bolt holes or what?
Old Nov 1, 2004 | 10:39 PM
i mean make the door work properly like it was never removed. i cant get mine right it is off by like a 1/4 in and it drives me nuts
Old Nov 1, 2004 | 10:49 PM
I'll take my chances with it, I'm not about to stand outside in the rain all night to fix it. Is there a proper method, like bolting it back in a certain order?
Old Nov 1, 2004 | 10:52 PM
honestly i have no clue but i put mine on as if it were closed then tightened the bolts (fender does have to come off ) thats how i did mine. thats the only advice i got on that
Old Nov 1, 2004 | 11:41 PM
99CivicExCoupe's Avatar
good luck, btw other than the 3 screws inside the hood and the 1 behind the door jam what other screws need to be unbolted to remove the fender?
Old Nov 1, 2004 | 11:55 PM
Default Re: del Sol door removal (99CivicExCoupe)
those three on top under the hood, in the door jam, in the headlamp opening, and at the front crowl
fast6fan
Jan 17, 2018 11:36 AM
tuvtec
Oct 8, 2014 12:01 AM
mikeycivics
Nov 28, 2011 08:16 AM
PinoyDelSol
Nov 10, 2007 12:11 AM
toben
Feb 24, 2007 08:05 PM
