help with my brake conversion, rim question
Old Nov 1, 2004 | 07:06 PM
90DALS's Avatar
Default help with my brake conversion, rim question
hey guys,
got a full rear integra suspension (trailing arms, upper/lower control carms, sway bar, calipers, everything) for 50.00 (91 integra).
anyways, got new rotors and pads coming in the mail this week. my question is, can i retain my 13" rims with this new rear set up?
13's fit my stock front brakes and rear drums fine, but this popped up in my head this week. will a 13" rim fit over the rear integra brake setup?
thanks,
steve.
Old Nov 1, 2004 | 07:10 PM
donuttes's Avatar
i know 13's fit on 92-96 si rear discs...not sure if the integra setup is bigger/smaller
Old Nov 1, 2004 | 07:39 PM
drdisco69's Avatar
Default Re: (donuttes)
You'll need 14" wheels, as those are the same brakes as the EX civics.
Old Nov 1, 2004 | 10:09 PM
HATCHFIEN's Avatar
yeah you could use 13's
Old Nov 4, 2004 | 06:38 PM
90DALS's Avatar
Default Re: (HATCHFIEN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HATCHFIEN &raquo;</TD></TR><TR><TD CLASS="quote">yeah you could use 13's
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 &raquo;</TD></TR><TR><TD CLASS="quote">You'll need 14" wheels, as those are the same brakes as the EX civics.</TD></TR></TABLE>
two different answers.
im talking about the REAR DISC BRAKES to make sure everyone knows that. im still using stock front civic disc. will a 13" rim fit over rear teg brakes?
Old Nov 4, 2004 | 06:40 PM
eumoria's Avatar
Default Re: (90DALS)
i don't know but if you have the whole suspension, just put your 13" steelie on the hub and you'll know
Old Nov 5, 2004 | 11:01 AM
90DALS's Avatar
Default Re: (eumoria)
i dont have the rotors here.
and the calipers ect arent installed. so i wouldnt know till i put the brakes on.
Old Nov 5, 2004 | 11:03 AM
TheSilentChamber's Avatar
13's will fit over it. It is the same setup as 90-91 crx si's had, and they came with 13's.
Old Nov 5, 2004 | 11:15 AM
EL Vap133's Avatar
Default Re: (TheSilentChamber)
I am sure it will fit since the rear disc brakes are smaller than front brakes/calipers/rotors.
Old Nov 5, 2004 | 11:31 AM
Putput's Avatar
I know for fact you can use the 13" stock steelies. Thats what was on my car.
Old Nov 6, 2004 | 05:31 AM
90DALS's Avatar
Default Re: (Putput)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Putput &raquo;</TD></TR><TR><TD CLASS="quote">I know for fact you can use the 13" stock steelies. Thats what was on my car.</TD></TR></TABLE>
thank you for the answer.
-stephen
Old Nov 6, 2004 | 05:35 AM
92integra_gs's Avatar
will that depends on which caliper you use... if you use the civic caliper which is smaller you can use 13 in rims but if you use the integra caliper you will have to use 14...HTH
FuNkDrSpOt
May 10, 2008 08:52 AM
socalrex88
Jul 17, 2007 03:08 AM
TyConway21
Sep 10, 2006 02:41 AM
SVOboy
Sep 26, 2005 02:00 PM
mp5o
12
Jul 14, 2005 04:13 PM
