Valve adjustment help needed...
Old Nov 1, 2004 | 06:36 PM
ShuaiGuy's Avatar
Default Valve adjustment help needed...
From what I've researched, intake is anywhere between .07-.09 and exhaust is .08 to .10
Can anyone verify which one is correct? Thanks!
Old Nov 9, 2004 | 08:14 PM
davidnguyen's Avatar
Default Re: Valve adjustment help needed... (ShuaiGuy)
Factory spec for the B18C1/5 and B16A is:
Intake: 0.006"-0.007"
Exhaust: 0.007"-0.008"
Old Nov 9, 2004 | 08:30 PM
Matty.'s Avatar
just go 0.007" intake & 0.008" exhaust.
Old Nov 10, 2004 | 04:03 AM
Finland's Avatar
Default Re: Valve adjustment help needed... (gumtape_deathmatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gumtape_deathmatch &raquo;</TD></TR><TR><TD CLASS="quote">just go 0.007" intake & 0.008" exhaust.</TD></TR></TABLE>
exactly.
Don't **** with trying to go too tight with the spec. I tried it, and ended up having a really shitty idle (poor vacuum), I went with 7/8 and it smoothed right out (better vacuum)
Old Nov 10, 2004 | 05:07 AM
len's Avatar
len
I always use .006 intake and .007 exhaust. Engine idles perfectly.
Old Nov 10, 2004 | 06:41 AM
typer_801's Avatar
Open your hood and read the specs posted on the underside, it clearly states the clearance tolerance.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ShuaiGuy &raquo;</TD></TR><TR><TD CLASS="quote">From what I've researched, intake is anywhere between .07-.09 and exhaust is .08 to .10
Can anyone verify which one is correct? Thanks!</TD></TR></TABLE>
Old Nov 10, 2004 | 07:01 AM
Chubz's Avatar
Default Re: Valve adjustment help needed... (len)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by len &raquo;</TD></TR><TR><TD CLASS="quote">I always use .006 intake and .007 exhaust. Engine idles perfectly. </TD></TR></TABLE>
Same here, and have never had any problems, i make sure the .006 goes in with some drag, and the .007 doesnt fit at all, the same with the exhaust side .007 with some drag, and .008 doesnt fit at all.
That netted me about 10 psi in each cylinder when comparing a previous compression test, to the one i did after the valve adjustment.
Linh.
Oct 12, 2006 08:03 PM
itr1244
Feb 1, 2006 11:58 AM
ELSpool
Feb 17, 2005 06:09 AM
G3NR8
May 4, 2004 02:30 PM
importimage
Jan 10, 2004 01:56 PM
