jdm gauge cluster.
Old Nov 1, 2004 | 06:18 PM
mikecivichb's Avatar
Default jdm gauge cluster.
I know I know I know I did a search and found soooo much **** about how to do the swap. But I am Having a problem With my swap. My car has been converted to obd1 p30 ecu chipped. So It doesnt look for the vss to activate vtec. Well let me get down to the point. I have the vss installed. With the vss allready installed into the tranny I hook up a ground and a 12v power. I then run the wire(signal) directly to the gauge cluster wire b1. It doesnt do anything The gauge cluster stays at 42 kmh. Now when I rub the two wires together(signal and b1) it goes up and then goes back down to 42kmh. I check to see if im still getting a ground a power to the vss and Im am. When I run the wire to the ecu for the hell of it. It doesnt do any thing. Any help would be appreciated. Thanks
Old Nov 2, 2004 | 02:28 AM
Default Re: jdm gauge cluster. (mikecivichb)
ttt
Old Nov 3, 2004 | 02:27 AM
help me ttt
Old Nov 3, 2004 | 12:22 PM
ttt
Old Nov 3, 2004 | 12:33 PM
Brownjd's Avatar
3 days and nobody can offer any help, wish i could, but all i can do for you is give you a free bump, cause i feel your pain.
Old Nov 3, 2004 | 02:38 PM
krazie1's Avatar
BANNED
Default Re: jdm gauge cluster. (Brownjd)
okay u not getting singal to ur cluster
but getting everything else to the vss???
hmmm...... sounds like the lcuster might be fucked tried it on someone else's car if u could if not u got it right
first must be send to the ecu and then to the cluster this is the way I got mine hooked up and running great....
Old Nov 4, 2004 | 02:31 AM
Default Re: jdm gauge cluster. (krazie1)
thanks alot for the bump. Im buying a new vss to see if that fixes the problem if it doesnt Ill just pick up a new cluster.
ballermc5
14
Oct 28, 2006 03:52 PM
Mister Jew
Sep 22, 2006 05:55 PM
RC211V
Honda Motorcycles
Oct 1, 2005 12:37 PM
nochance
May 9, 2005 10:54 AM
FakeJDMEF8
Nov 7, 2004 07:22 PM
