CTR pistons in a B18C1?
Old Dec 21, 2001 | 04:59 PM
speedymon's Avatar
Default CTR pistons in a B18C1?
I did a search and still no clear answer. Will these be a direct drop in into my 96 GSR?
Old Dec 21, 2001 | 08:38 PM
SpeedracerS4's Avatar
Default Re: CTR pistons in a B18C1? (speedymon)
Yes it will be a direct drop, but you need to use typer/b16a head because if you use your gsr head the compression will be to high for pump gas!!
Old Dec 22, 2001 | 04:03 AM
speedymon's Avatar
Default Re: CTR pistons in a B18C1? (SpeedracerS4)
Pho real! I'll stick with the JDM ITRs
Old Dec 22, 2001 | 07:32 AM
rainforest's Avatar
12.1/2 compression on that set-up so get some mods before you do that. To help you from detonation
Old Dec 22, 2001 | 01:19 PM
ahcjar103's Avatar
Default Re: CTR pistons in a B18C1? (rainforest)
it won't be too high for pump gas. you just have to tune it and upgrade fuel delivery, etc. c-speed's integra it's currently running 13.5:1 on pump gas. just get it on the dyno and you're fine.
emissionsux
May 8, 2003 06:16 PM
emissionsux
Apr 24, 2003 01:00 PM
ALMOSTAFERIO
Apr 10, 2003 06:05 PM
JDM_ITR
Aug 20, 2002 11:16 PM
JSpecwest
Oct 15, 2001 08:08 PM
