More Re: Eratic Tach!
Old Dec 21, 2001 | 04:40 PM
scottishbastard's Avatar
Default More Re: Eratic Tach!
Hey,
I own a '93 Integra with a B16A, ITR cams and intake manifold. The engine revs up from 900 to 1500 RPM, after warm-up, every few seconds while stopped at a light, etc. Is there something I need to connect or is missing that I forgot about? I did notice that there was a vacuum hose fitting on top of the throttle body that I could not connect to the ITR manifold with a hose. I appreciate your help with this.
Also, I know you guys/gals are not into installing a short throw shifter, ruining the synchros and all. But what do I do to firm up the play in my stock one besides putting in polyurethane bushings, which I have already done?
Thank you
Old Dec 21, 2001 | 06:47 PM
civicjunkie's Avatar
New User
Default Re: More Re: Eratic Tach! (scottishbastard)
check to see if ur iacv(idle air control valve) is faulty 9 times out of ten it needs replacing
SanyaK
Mar 2, 2009 11:08 AM
Braco11
17
Feb 12, 2008 12:32 PM
da6jdmteg
Aug 15, 2006 10:08 AM
92_EGhatch
Jan 27, 2005 11:18 AM
