Mini-Me Tech Question
Old Nov 1, 2004 | 02:27 PM
type_rev's Avatar
Default Mini-Me Tech Question
Guys, I'm finishing up my mini-me swap for my crx. I have a '89 crx dx....the stock engine is a d15b2 w/dpfi.
I'm installing a mini-me in the following configuration:
MPFI/OBD1 w/Kenji chipped P28 ecu & JK obd0-->obd1 conversion harness
Block - d16a6 from a 90 crx Si
Head - d16z6 from a 93 Civic Si
Intake Mani - d16y8 from 96 & up EK 5 Spd.
QUESTION:
1. What throttle cable and fuel line should I use?
2. Since the Y8 IM is obd2, what should I do about the MAP sensor on top of the throttle body?
Any help is much appreciated.
Modified by type_rev at 12:00 AM 11/2/2004
Old Nov 1, 2004 | 08:00 PM
type_rev's Avatar
Default Re: Mini-Me Tech Question (type_rev)
Old Nov 1, 2004 | 08:11 PM
drdisco69's Avatar
I don't know much about the single cams, but if you are using the map sensor on the firewall, just forget about the one on the throttle body.
Jim Truett's Avatar
1. HF or Si should be fine.
2. Plug the hole and use the stock MAP, or lengthen the wire harness to reach the TB mounted MAP.
Old Nov 1, 2004 | 08:15 PM
drdisco69's Avatar
Default Re: Mini-Me Tech Question (Jim Truett)
I'd use the map sensor that's in there to plug the hole. Why do you reccomend removing it?
Old Nov 1, 2004 | 08:28 PM
Jim Truett's Avatar
Default Re: Mini-Me Tech Question (drdisco69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 &raquo;</TD></TR><TR><TD CLASS="quote">I'd use the map sensor that's in there to plug the hole. Why do you reccomend removing it?</TD></TR></TABLE>
It looks ghetto, and won't pass emissions in CA.
Old Nov 1, 2004 | 08:52 PM
drdisco69's Avatar
I don't think it looks that bad. How do they consider the map sensor an emissiosn component? I almost don't want to know, CA is pretty wierd about some stuff.
Old Nov 3, 2004 | 12:41 AM
type_rev's Avatar
Thanks for all the info guys, keep the comments/suggestions coming.
Old Nov 3, 2004 | 08:17 AM
Macleod95Civic's Avatar
hey dude, i just dropped a minime in my eg civic coupe. i need help hooking up the vtec from the p28 ecu to my current wire harness. my car was previously non vtec. now it is. please check out my post for more details.. please help me dude!
https://honda-tech.com/zerothread?id=1043957
Old Nov 3, 2004 | 01:36 PM
Jim Truett's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 &raquo;</TD></TR><TR><TD CLASS="quote">How do they consider the map sensor an emissiosn component?</TD></TR></TABLE>
Probably because it has a key role in the fueling of the engine. You know what it does, right?
Old Nov 8, 2004 | 10:28 AM
type_rev's Avatar
Thanks for the info guys....Does anyone have a pic of a Y8 IM on a Z6 head? Please post it up.
Old Nov 8, 2004 | 11:39 AM
mike_belben@yahoo.com's Avatar
From: not riding any bandwagons in, massachusetts, usa
the valve widths between z6 and a6 block are quite different. the z6 ports are spaced wider and the stock a6 piston valve reliefs will not match the z6 head. apparently people get away with it, but i would be leary of excessive cam timing changes, head milling or high lift, or high rpm for that matter.
Old Nov 11, 2004 | 02:06 AM
type_rev's Avatar
Old Nov 11, 2004 | 05:38 AM
Blown90hatcH's Avatar
I would make a small little aluminum bracket with two holes on the ends for the bolts that would normally hold the map down. I would cut the bolts down in length and reuse the stock black oring underneath the bracker. Both that sucker down.
Or you can use the map that belongs there and extend the wires from the firewall to the sensor.
Old Nov 11, 2004 | 08:48 AM
type_rev's Avatar
Default Re: Mini-Me Tech Question (Blown90hatcH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blown90hatcH &raquo;</TD></TR><TR><TD CLASS="quote">I would make a small little aluminum bracket with two holes on the ends for the bolts that would normally hold the map down. I would cut the bolts down in length and reuse the stock black oring underneath the bracker. Both that sucker down.
Or you can use the map that belongs there and extend the wires from the firewall to the sensor.</TD></TR></TABLE>
Thanks for the advise...I think I'm going to do that.
B_Still
Oct 17, 2008 01:39 AM
atarigamer01
Jul 1, 2008 07:29 AM
Hondasaurs
May 26, 2003 09:50 PM
SOcalistreetracer
Jun 27, 2002 12:13 PM
