stuck (rusted) flywheel
Old Nov 1, 2004 | 01:29 PM
Xpos's Avatar
Default stuck (rusted) flywheel
Hello
Background:
1. I have bought the SIR-II swap part number 30005 from Hmotorsonline.com
2. I did the swap on the 93 CX.
3. The Engine started fine.
Problem:
1. The clutch could not be shift into GEAR when the Engine is running.
2. Shifts fine when the engine is OFF (of course).
3. It is probably Rusted and Mated together with the flywheel.
Question:
1. Please tell me there is a soluntion to this other than a new clutch kit.
thank you
Modified by Xpos at 4:44 PM 11/1/2004
Old Nov 1, 2004 | 01:35 PM
drdisco69's Avatar
Default Re: stuck (rusted) flywheel (Xpos)
That happened to a car I had. I found with enough man handling, I was able to break the clutch away from the flywheel and drive the car. Then I replaced the clutch.
Old Nov 1, 2004 | 01:41 PM
Xpos's Avatar
Default Re: stuck (drdisco69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 &raquo;</TD></TR><TR><TD CLASS="quote">I found with enough man handling, I was able to break the clutch away from the flywheel and drive the car.</TD></TR></TABLE>
Thanks for the reply.
What do you mean?
How did you do it?
Please give me some more detail.
thanks
Old Nov 1, 2004 | 01:58 PM
drdisco69's Avatar
Default Re: stuck (Xpos)
It involved a lot of abusing the sychros to get it into gear and moving, then putting the clutch in and stomping on and off the gas, like a retard learning to drive stick.
Old Nov 1, 2004 | 02:01 PM
atcrx's Avatar
We had a tractor that the clutch stuck on it. Had to drive it around with the clutch mashed in goosing the throttle and mashing the brakes at the same time in high gear... it finally broke loose. works good now no problem
Old Nov 1, 2004 | 02:54 PM
Xpos's Avatar
I'll will try that. much thanks guys.
Old Nov 1, 2004 | 03:19 PM
msmotorsports's Avatar
Default Re: (Xpos)
The clutch could be damaged as well. This would cause the clutch to not disengage the flywheel.
Old Nov 1, 2004 | 04:32 PM
ogabudiah's Avatar
Default Re: (msmotorsports)
Haha, Damaged. It better be damaged if its rusted together.
Old Nov 1, 2004 | 04:45 PM
HONDA_TYPE_R's Avatar
Default Re: (ogabudiah)
Probably should have replaced it when you bought it...but I would definitely try what these cats are recommending. Definitely won't be good for your tranny though.
Old Nov 1, 2004 | 04:50 PM
drdisco69's Avatar
Default Re: (HONDA_TYPE_R)
Neh, it's fine. The tires will break loose before the trans does. I hope.
Old Nov 1, 2004 | 06:23 PM
skunk2finatic's Avatar
I got my motor from Hmotorsonline as well. I didn't have any troubles like that, but then again, I was weary of the mexican guy I was talking to about it. So I pulled the tranny off while it was still on the palet and basically went through the motor and replaced all the seals, including rear-main, which you need to take the flywheel off to even get too. Everything looked good, though I did notice it was EXTREMELY hard to get the flywheel off.
Old Nov 2, 2004 | 10:09 AM
Xpos's Avatar
Default Re: stuck (skunk2finatic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunk2finatic &raquo;</TD></TR><TR><TD CLASS="quote">I got my motor from Hmotorsonline as well. I didn't have any troubles like that, but then again, I was weary of the mexican guy I was talking to about it. So I pulled the tranny off while it was still on the palet and basically went through the motor and replaced all the seals, including rear-main, which you need to take the flywheel off to even get too. Everything looked good, though I did notice it was EXTREMELY hard to get the flywheel off.</TD></TR></TABLE>
My luck with online orders.
I have no time to "break" my tranny just yet *cross my fingers*, but I will definately try to get it running.
Steve, from HMO, is sending me the clutch kit "for customer satisfation"; he so called it. I will hate the fact that I will have to change it.
Old Nov 2, 2004 | 08:21 PM
Change it for peace of mind. Hope all works out well.
Old Nov 2, 2004 | 08:50 PM
senpai's Avatar
It could also be the shifter fork holding the throwout bearing (not allowing enough travel to engage/disengage clutch).
Happened to me
Old Nov 3, 2004 | 12:38 AM
honda_power69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Xpos &raquo;</TD></TR><TR><TD CLASS="quote">My luck with online orders.
Steve, from HMO, is sending me the clutch kit "for customer satisfation"; he so called it. I will hate the fact that I will have to change it.</TD></TR></TABLE>
Well punch me in the face and call me Suzy. You mean someone from Hmotorsonline actually called you back after they got your money? Let alone to send you something for free? I swear the devil just started handing out glassses of ice water in Hell when I just read that...
Old Nov 3, 2004 | 11:09 AM
Xpos's Avatar
Default Re: stuck (senpai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by senpai &raquo;</TD></TR><TR><TD CLASS="quote">It could also be the shifter fork holding the throwout bearing (not allowing enough travel to engage/disengage clutch).
Happened to me </TD></TR></TABLE>
How do your problem got resolved?
Old Nov 3, 2004 | 11:17 AM
Xpos's Avatar
Default Re: stuck (honda_power69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda_power69 &raquo;</TD></TR><TR><TD CLASS="quote">
Well punch me in the face and call me Suzy. You mean someone from Hmotorsonline actually called you back after they got your money? Let alone to send you something for free? I swear the devil just started handing out glassses of ice water in Hell when I just read that...</TD></TR></TABLE>
He did not call me back. I called him. He told me the "used" clutch kit will be at my door by the end of this week for free. YES, NO CHARGE.
I'll see if he's a GOOD man or NOT.
========&gt; I have tried driving the car with the clutch engaged "Jerking it" thing. It does not work. I have drove 4 rounds around my block.
========&gt; any more HELP
thanks
Old Nov 3, 2004 | 12:02 PM
Bandit74's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 &raquo;</TD></TR><TR><TD CLASS="quote">It involved a lot of abusing the sychros to get it into gear and moving, then putting the clutch in and stomping on and off the gas, like a retard learning to drive stick.</TD></TR></TABLE>lol.
Old Nov 8, 2004 | 06:09 AM
Xpos's Avatar
Last Option: Buy a new Clutch kit and gather some more times.
bank2me
Jun 5, 2011 02:13 PM
BB1LOViN
Oct 3, 2007 09:18 AM
3vilMonkey!
Honda S2000
27
Mar 19, 2006 10:13 PM
cdnB18C1
Feb 25, 2006 11:08 AM
JdmAcclude
May 6, 2004 12:03 PM
