92-95 clutch on a 90-91 tranny/flywheel? does it work?
Old Nov 1, 2004 | 11:13 AM
I Have an STD's Avatar
wrenchin'
Default 92-95 clutch on a 90-91 tranny/flywheel? does it work?
my buddy is gonna almost GIVE away his act 6 puck to me. its meant for a 92-95 tranny. will it work on my 90-91 trans with a 90-91 flywheel? simple yes or no will do, tried to search.
Brett
Old Nov 1, 2004 | 11:51 AM
tgreaves's Avatar
Default Re: 92-95 clutch on a 90-91 tranny/flywheel? does it work? (I Have an STD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I Have an STD &raquo;</TD></TR><TR><TD CLASS="quote">my buddy is gonna almost GIVE away his act 6 puck to me. its meant for a 92-95 tranny. will it work on my 90-91 trans with a 90-91 flywheel? simple yes or no will do, tried to search.
Brett</TD></TR></TABLE>
Yep, It sure will.. You just need to use a 90-91 throwout bearing and your good to go.. You can even try to get his 92-95 flywheel so you dont have to get yours machined..
Old Nov 1, 2004 | 11:57 AM
wrenchin'
Default Re: 92-95 clutch on a 90-91 tranny/flywheel? does it work? (tgreaves)
nice. thanks alot. im not going to be using the stock flywheel. im going to be using a fidanza 8lb flywheel. do i order it for a 90-91 or a 92-95. or are they the same part number?
Brett
Old Nov 1, 2004 | 12:00 PM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I Have an STD &raquo;</TD></TR><TR><TD CLASS="quote">nice. thanks alot. im not going to be using the stock flywheel. im going to be using a fidanza 8lb flywheel. do i order it for a 90-91 or a 92-95. or are they the same part number?
Same part number.. The 90-95's are all the same flywheel and clutch except for the throwout bearing in the 90-91's..
Old Nov 1, 2004 | 12:01 PM
wrenchin'
THANK YOU you have been a huge help!!!
Brett
Old Nov 1, 2004 | 12:03 PM
tgreaves's Avatar
No problem..
alexsracing
May 19, 2005 02:54 PM
denzel
Feb 19, 2005 08:03 AM
Kyles ej1
Nov 3, 2004 07:02 PM
xXx Justin xXx
11
Nov 19, 2002 08:53 PM
