Head Disassembly
Old Nov 1, 2004 | 10:23 AM
STS_Underdog's Avatar
Default Head Disassembly
I'm taking the head from my Civic to the machine shop and need to get the cam out before I take it in to save some money. I've pulled the 18 bolts that hold the rocker assembly to the head but it still won't come loose. Is there anything else that needs to be removed? Should the rocker assembly just lift off the head or am I missing something? TIA!
Old Nov 1, 2004 | 10:26 AM
MatHadder's Avatar
Default Re: Head Disassembly (STS_Underdog)
When i did it, it kind of stuck on. you might need to find a way to pry it off. be careful though, and look it over so you dont break anything.
Old Nov 1, 2004 | 10:44 AM
rjay8604's Avatar
Default Re: Head Disassembly (MatHadder)
Pretty much any engine and similar parts that have extrememly precise surfaces and dowel pins are going to be seized together, so you need to "break" it free. Like connecting rod bearing caps, main bearing caps, the cylinder head, oil pan, sometimes wheels and the hubs seize. So keep this in mind on all your mechanical "fix-it" type jobs. Good luck with it.
Old Nov 1, 2004 | 10:51 AM
Yeah, I just wanted to make sure I wasn't missing anything. When I pulled the oil pump I thought it was stuck and it turned out I had missed a bolt. Fortunately I figure it out before I broke anything!
Old Nov 1, 2004 | 10:52 AM
1 point 6's Avatar
Down Since Day 1
Community Builder
Community Influencer
Just get out a ball peened hammer and just bang on the lobes until it falls out. jk.
91civicEX
115
Apr 19, 2016 05:44 PM
teal_dx
Aug 28, 2007 11:13 AM
Chrys007
Jun 26, 2007 01:50 PM
jonathan13
Aug 18, 2005 06:04 PM
