P28 ECU Burnig Up Q???
Old Nov 1, 2004 | 09:22 AM
spoonhatchblack's Avatar
Default P28 ECU Burnig Up Q???
Help me Guys.
Heres the Prob.
I currently running a chip P72 ECU.
I Bought a stock P28 ECU and Plugged it in my ride and smelled the ECU Frying up!!
I then Used my Chipped P28 ECU that i was running before the P72 ECU...and notice it Burnt UP Also???
Can someone here Help me Figure out this Problem???
Old Nov 1, 2004 | 10:57 AM
HRTuning's Avatar
Default Re: P28 ECU Burnig Up Q??? (spoonhatchblack)
Do the ECUs work anymore? Are you throwing any codes now? Check to see if it's Q31 that's burning up... It's close to the ECU plugs on the board...
Old Nov 4, 2004 | 10:06 AM
Default Re: P28 ECU Burnig Up Q??? (HRTuning)
yea it is Q31.
what can it be????
Old Nov 4, 2004 | 10:12 AM
HRTuning's Avatar
Your wiring for the purge canister solenoid... You may have even plugged the IAT sensor into the PCS plug...
JeffBro
Engine Management and Tuning
11
Jan 5, 2011 04:20 AM
Jap_Spec_Imports
Oct 29, 2009 08:32 PM
G MoNeY Ej1
May 2, 2008 09:56 PM
