Leak In EVAP SYstem
Old Nov 1, 2004 | 06:56 AM
SIMATIC's Avatar
Default Leak In EVAP SYstem
whats up
i got a 98 accord ex 5 spd, it has 138k on it. redently the engine check light came on. so i trouble shooted the code and it was "leak in EVAP Control System". what can that be? my mecchanic wants $75 just to perform the smog test! thats insane. Any one have any ideas what it cane be? thanks alot
Old Nov 1, 2004 | 09:28 AM
JimBlake's Avatar
Default Re: Leak In EVAP SYstem (SIMATIC)
What code? I had a P1457 & wrote it up partway down in this thread...
https://honda-tech.com/zerothread?id=748876
P1456 would include instead, the gas tank & a couple different components, but the Helm book has a pretty similar procedure to check THAT stuff out. If you just got 90 from the blinking-licht code, then it might be either one of these.
Old Nov 1, 2004 | 04:36 PM
SIMATIC's Avatar
Default Re: Leak In EVAP SYstem (JimBlake)
EVAP Emission Control System Leak Detected (Control Canister System) P1457, can i check the canister my self? or do i need a smog test performed? any advice? thanks alot
http://www.troublecodes.net/honda/hondaobd2.shtml
Old Nov 1, 2004 | 05:14 PM
bill-71SS's Avatar
check the canister vent shut valve on the side of the canisret,known to go bad a lot.
Old Nov 1, 2004 | 05:48 PM
SIMATIC's Avatar
Default Re: Leak In EVAP SYstem (bill-71SS)
i dunno what exactly im looking at, i get my car back 2mkorrow, sol ill jack it up n takea LOOK. its under the driver side rear seat right? well how do i tell if its bad? where is this vent exactly loacated? sorry for being an ***, i never dealt with OB2 before.thanks again!!
u think its time to change my o2 sensors? its got 138k on it n i dunno if the preiuosv owner changed them...found alll of his receipts in the glove compartment. nothing bout o2 sensors.
i got bad gass milage like 14 mpg
did a recent tune up. i keep up maintance on my car!
Modified by SIMATIC at 3:03 AM 11/2/2004
Modified by SIMATIC at 4:05 AM 11/2/2004
Modified by SIMATIC at 4:06 AM 11/2/2004
Old Nov 2, 2004 | 04:21 AM
JimBlake's Avatar
Did you read my summary of the stuff to check? Got a multi-meter? Couple jumper wires? MityVac?
#6 is the EVAP canister
#8 is the vent-shut valve
#14 is the 2-way valve (#27 is it's cover)
Old Nov 2, 2004 | 06:39 AM
SIMATIC's Avatar
thanks! yes i did get that summary thank you very much. i gave up cuz i didnt understand what anythiing was. but now im gona jack up the car n take a look..can you send it again? i appriciate it
Old Nov 2, 2004 | 07:05 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIMATIC &raquo;</TD></TR><TR><TD CLASS="quote">...can you send it again?</TD></TR></TABLE>It's the link in my other message, above. About 3/4 down towards the bottom of that thread...
Can you get your hands on a Helm book? (Library?) The pictures & descriptions in there are way better; they go on for several pages. Especially if you get to the later checks where you have to connect the hoses special ways for the test.
On mine it was the vent-shut valve, & it sounds like that's pretty common. When I tried to energize that valve with jumpers to the battery, it didn't even click. It was corroded into a lump so the problem was sorta obvious... (You could take a chance & jump right to that check?)
Old Nov 2, 2004 | 09:44 AM
SIMATIC's Avatar
u been very helpful i check it out 2day hopeuflly iget my car back later on
Old Nov 2, 2004 | 10:19 AM
siblueg's Avatar
did you have you r key on while you where getting gas or somthing, sometimes it picks up fumes from getting gas. i dunno just a thought
Old Nov 2, 2004 | 05:11 PM
SIMATIC's Avatar
Default Re: Leak In EVAP SYstem (siblueg)
na wasnt that...i even changed the fuel cap.. and when i changed the fuel cap the "maint" ligfht flashes now 5 times then shuts off when i start the car
Old Nov 3, 2004 | 03:53 AM
JimBlake's Avatar
The maintenance light has nothing to do with this. Just a mileage reminder for scheduled maintenance. Press the odometer-reset button when the car's off, hold it while you turn on the car, keep holding it until the maint. light goes off.
There's like a half dozen valves & things that can set P1457, along with leaky vacuum hoses in between them. You just gotta go thru them until you find something that isn't right...
Old Nov 3, 2004 | 05:05 AM
SIMATIC's Avatar
OK THANKS,,,I IWILL JACK IT UP AND WHAT EVER DOESNT SEEM RIGHT, ILL POST.THANKS ALOT, U GUYS ARE HELPFUL!
well i jacked it up, not exactly sure if i could tell what was wrong...but i saw that cylinder that sits upright. i dunno if it was dirt. but the side that was towards the inside looks like it had a long stain on it, running from the top to the bottom. some kinda build up. i dunno if its dirt, but it looks like mabe its burnt. i dunno its a brownish stain. i duno if thats even anything. all the hoses looked ok. thats bout it. i duno what else.
Modified by SIMATIC at 2:18 AM 11/4/2004
Old Nov 8, 2004 | 05:11 AM
SIMATIC's Avatar
changed the gas cap and reset the light....its been 4 days no light yet....lets pray!!
DIESEL5
23
Aug 3, 2010 06:21 PM
FRKWOO
Nov 8, 2008 09:19 PM
TheMaroonAvenger
Jul 18, 2007 06:58 PM
STubs5000
Nov 2, 2005 05:42 PM
b 1 6 a 2
Dec 20, 2004 04:26 AM
