94 teg LS to GSR motor swap
Old Dec 21, 2001 | 12:52 PM
hahagasdcrx's Avatar
Default 94 teg LS to GSR motor swap
need to know what do i need to complete the swap as fast and easily as possible. i have the b18b in it now going to a b18c1 need an ECU i know but what about the wiring for the vtec solenoid and knock sensor and are the mounts the same?do i need a different throttle cable...or anything else or link me to a site with all the info thanx.......
Old Dec 21, 2001 | 02:35 PM
Backyard Speical's Avatar
Default Re: 94 teg LS to GSR motor swap (90crxzcgasd)
you need a different throttle bracket but that should come with the motor.
The Vtec wiring is just three wires, and i beleive the B18B blocks already have a knock sensor. About the motor mounts they are all the same.
good luck on your swap. let me know if you run into any other problems
Old Dec 21, 2001 | 07:32 PM
IMPATIENT's Avatar
Default Re: 94 teg LS to GSR motor swap (Prodigy 2.2 EK)
94-97 B18B, don't have knock sensors...........
Old Dec 22, 2001 | 07:12 AM
Big Teggie's Avatar
Default Re: 94 teg LS to GSR motor swap (IMPATIENT)
Searsh for or instant message redteggy, he did a gsr swap into his 94 RS. Its a pretty straight forward swap, good if its your first swap.
Old Dec 22, 2001 | 06:27 PM
redteggy @ what?????
Old Dec 23, 2001 | 12:32 AM
uncleben's Avatar
ummm. you see the little "IM" button under the name/avatar, click that!
Old Dec 23, 2001 | 01:19 PM
under_psi's Avatar
Default Re: 94 teg LS to GSR motor swap (uncleben)
you can use your own axles/mounts/shift linkage....your B18B1 is OBD1, if the B18C1 is also OBD1 then you'll only need to add three wires to your own ecu harness. If the B18C1 is OBD2 then it'll be a LOT more complicated...same with JDM(non OBD).
I have an OBD1 B18C1 in my 95 RS and the swap was a sinch
Old Dec 23, 2001 | 04:00 PM
Duck Sauce's Avatar
Default Re: 94 teg LS to GSR motor swap (T.O.tegs)
Why would you want to perform a motor swap for only 30HP??! Just take your LS and boost that ****! I think a LS/turbo would be a hell of a lot quicker than a GSR.
Old Dec 23, 2001 | 04:29 PM
quikrpm'z's Avatar
Default Re: 94 teg LS to GSR motor swap (www.s4-mtm.com)
maybe he doesnt want the headaches that come along with a turbo. Go for the swap.
Old Dec 23, 2001 | 07:38 PM
Default Re: 94 teg LS to GSR motor swap (quikrpm)
the swap would be great, but i beleive turbo would be better for the price. Both is going to run you about 3000 dollars. His right, no headaches for the GSR swap, and staying all motor. But i strongly beleive if you get a good turbo setup, you'll be in good shape also. NO headaches, But just way more HP than the GSRswap.
Let me know what i can do for you. I have a GSR and Drag turbo kit right now. please give us a call if you're interested in those items, please remind me you're an honda-tech member. i'll be sure to give you a discount.
thanks
Old Aug 31, 2005 | 09:08 AM
HomeDepotMade's Avatar
Default Re: 94 teg LS to GSR motor swap (Backyard Speical)
hey if its obd1 then get like a cheap ecu and chip it without a ks and speed limit. i have a p28 with type r basemap it was going in my crvtec but i found a cheap GSR motor so im going for that one.
Old Nov 22, 2011 | 10:36 AM
sebTeggy's Avatar
Bump, will be possibly picking up a 96 to swap into my 95. What is needed exactly?
motor/tranny
ecu
vtec subharness (ez)
which sensors will I be missing?
I will have to convert to obd2 right? Could I get an obd1 gsr ecu?
Thanks
Mjohnson94eg
Dec 21, 2014 06:39 AM
ricky bobbay
Feb 15, 2012 12:11 PM
94IntegraLs04
Jun 20, 2005 07:30 PM
