Chiped p28 or GSR computer
Old Oct 31, 2004 | 10:56 PM
Mr Instigate's Avatar
Default Chiped p28 or GSR computer
I have a chiped p28 and v-tech does not hit hard. It kinda slides into v-tech at around 5100rpm. I think it is a skunk 2 chip. Do you think a GSR (p72?) will hit v-tech hard??
Old Oct 31, 2004 | 11:28 PM
Guest
Posts: n/a
Default Re: Chiped p28 or GSR computer (Mr Instigate)
Got a v-tech chip or a vtec chip? That makes a big difference
Vtec hits hard on my p28 yO. Try another chip
Old Nov 1, 2004 | 05:49 AM
Default Re: Chiped p28 or GSR computer (#1)
vtec does not hit hard with a p28. so sorry about vtec spelling but dont respond if ur goin to be a smart ***
Old Nov 1, 2004 | 07:52 AM
GDM Z28's Avatar
If an ecu is chipped it does not matter if its a p28 or a p72 its going to tell the car to do what the chip is telling it to do. Maybe vtec is engaging too early but what do you expect? Its not going to hit like a n2o or boost hit.....
Old Nov 1, 2004 | 09:09 AM
H23AHybridEG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Instigate &raquo;</TD></TR><TR><TD CLASS="quote">vtec does not hit hard with a p28.</TD></TR></TABLE>
What the **** does that mean???
Old Nov 1, 2004 | 02:16 PM
Default Re: Chiped p28 or GSR computer (civicflnum1)
forget it!
Old Nov 1, 2004 | 03:37 PM
LoSt is BlaCk's Avatar
what mods...sometimes the intake or exhaust system will change the actual sound of vtec popping, either way it's still functioning...right? you might need a better chip with a better map...but the sound it not what matter really...
Old Nov 1, 2004 | 05:16 PM
PHiZ's Avatar
Default Re: Chiped p28 or GSR computer (LoStMyBoOsT)
Um what motor, single cams Vtec isn't very loud.
-PHiZ
Old Nov 1, 2004 | 05:54 PM
Default Re: Chiped p28 or GSR computer (PHiZ)
its a b16 with a cold air intake and apex world sport cat back.
Old Nov 1, 2004 | 06:04 PM
Jim Truett's Avatar
A good tune generally leaves little perceived "boost" at the VTEC crossover, because the cams are switched at a point where the two torque curves meet.
I personally think that the Junk2 chip needs to be thrown in the trash, and a new proper dyno tune done.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LoStMyBoOsT &raquo;</TD></TR><TR><TD CLASS="quote">you might need a better chip with a better map...</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicflnum1 &raquo;</TD></TR><TR><TD CLASS="quote">If an ecu is chipped it does not matter if its a p28 or a p72 its going to tell the car to do what the chip is telling it to do.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Instigate &raquo;</TD></TR><TR><TD CLASS="quote">vtec does not hit hard with a p28. so sorry about vtec spelling but dont respond if ur goin to be a smart ***</TD></TR></TABLE>
Try another chip
Old Nov 1, 2004 | 07:19 PM
muskrat hatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jim Truett &raquo;</TD></TR><TR><TD CLASS="quote">A good tune generally leaves little perceived "boost" at the VTEC crossover, because the cams are switched at a point where the two torque curves meet.
I personally think that the Junk2 chip needs to be thrown in the trash, and a new proper dyno tune done. </TD></TR></TABLE>
yea vtec isn't suppose to be a rough transition, it's made to be smooth and daily driver-friendly so i'm pretty sure a gsr ecu wouldn't help anything. but yea i agree, get it tuned.
Old Nov 1, 2004 | 11:04 PM
PHiZ's Avatar
Default Re: Chiped p28 or GSR computer (chatch152)
But I've never been in a B16 where it didn't scream after vtec...
-PHiZ
Old Nov 1, 2004 | 11:56 PM
Sack Master's Avatar
I'm sure the issue is not your vtec. It either engages or doesn't. Maybe needs tuning, maybe the motor is just old and beat up, maybe just needs a tune up. Could be any of that.
Old Nov 2, 2004 | 06:35 AM
DaX's Avatar
DaX
Loved
Community Favorite
Hondata has stated that a properly tuned ECU will have such a smooth transition into VTEC crossover that it's barely noticable.
Old Nov 2, 2004 | 07:17 AM
egsleepercivic's Avatar
get a stock P30, vtec should be around 5800
Thump_eg94
Jun 25, 2010 12:37 PM
madcrx69
Engine Management and Tuning
Jul 21, 2009 08:42 AM
mudd_butt
Mar 28, 2008 03:49 PM
redline23
May 7, 2004 06:10 AM
