main cap bolts??
Old Oct 31, 2004 | 06:04 PM
dumpeDc2's Avatar
I'm a Jackass
Default main cap bolts??
ok I just got my block back from the machine shop and when the did the bore and hone I had them use the stock main bolts. Now I want to put some AEBS ones in and I know they have a diffrent tq spec will this affect anything when using the after market bolts???
Old Oct 31, 2004 | 06:05 PM
dumpeDc2's Avatar
I'm a Jackass
Default Re: main cap bolts?? (dumpeDc2)
bump some one has to know.
Old Oct 31, 2004 | 10:10 PM
dumpeDc2's Avatar
I'm a Jackass
umm.. anyone
Old Nov 1, 2004 | 05:33 AM
GDM Z28's Avatar
All you did was bore and hone? If so i do not believe it would mess ne thing up. If you line bored or something else like that then it might but i do not believe so. I would use them. BTW how much did those cost?
Old Nov 1, 2004 | 06:23 AM
dumpeDc2's Avatar
I'm a Jackass
Default Re: main cap bolts?? (civicflnum1)
there like 110 form AEBS witch is right by my house
Old Nov 1, 2004 | 06:48 AM
mmuller's Avatar
Mad Scientist
fi you change the main bolts to higher torque ones; its most likely gonna egg shape the mains so you gonna have to get them line bored. Or you might be lucky and be able to get away with it.
Old Nov 1, 2004 | 07:17 AM
GDM Z28's Avatar
Default Re: main cap bolts?? (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">fi you change the main bolts to higher torque ones; its most likely gonna egg shape the mains so you gonna have to get them line bored. Or you might be lucky and be able to get away with it.</TD></TR></TABLE>
If it has different torque specs it could be because its a different material and it streches differently so they change the torque specs to make up for it. I would talk to AEBS about it
Old Nov 1, 2004 | 09:15 AM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicflnum1 &raquo;</TD></TR><TR><TD CLASS="quote">
If it has different torque specs it could be because its a different material and it streches differently so they change the torque specs to make up for it. </TD></TR></TABLE>
no.
Old Nov 6, 2004 | 12:24 PM
dumpeDc2's Avatar
I'm a Jackass
I just got the mains line borded because thats what it said I should do in the instructiions
hondamark35
Aug 28, 2008 01:55 PM
killerpenguin21
Jul 25, 2006 06:18 PM
B18_Civic
Aug 19, 2005 07:16 PM
MrBui
Mar 16, 2004 01:35 PM
VTgringo
Mar 9, 2004 03:04 PM
