B20B with ARIAS pistons - need resleeved?
Old Oct 31, 2004 | 04:30 PM
gamakichi77's Avatar
Default B20B with ARIAS pistons - need resleeved?
i would like to know is it neccessary for me to resleeved my B20B block if i go for 85mm ARIAS pistons with 12.5.1:1 CR with stock lightened stock B20B cranks and rods. Just rematched my stock sleeved with new ARIAS 85mm pistons.........advise is really appreciate. thanks
Old Nov 1, 2004 | 05:35 AM
GDM Z28's Avatar
Default Re: B20B with ARIAS pistons - need resleeved? (acidburns_di)
Id be worried about running that compression on a stock b20....so i wouldnt go 85mm cause your just taking more away from the already weak sleeves. Just go 84.....you wont notice
Old Nov 1, 2004 | 05:46 AM
AlterEgo's Avatar
Default Re: B20B with ARIAS pistons - need resleeved? (civicflnum1)
^^ word.
Old Nov 1, 2004 | 05:57 AM
GDM Z28's Avatar
Default Re: B20B with ARIAS pistons - need resleeved? (AlterEgo)
BTW since your already in the motor change the rods as well. Your motor is only has strong as its weakest parts
Old Nov 1, 2004 | 04:08 PM
should i change my rods to either Golden Eagles or Crower?....and is it still safe if i use stock sleeves ( just rematched the 85mm bore )
Old Nov 1, 2004 | 04:15 PM
GDM Z28's Avatar
did you read ne thing i wrote?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicflnum1 &raquo;</TD></TR><TR><TD CLASS="quote">BTW since your already in the motor change the rods as well. Your motor is only has strong as its weakest parts </TD></TR></TABLE>
AND
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicflnum1 &raquo;</TD></TR><TR><TD CLASS="quote">Id be worried about running that compression on a stock b20....so i wouldnt go 85mm cause your just taking more away from the already weak sleeves. Just go 84.....you wont notice </TD></TR></TABLE>
Old Nov 1, 2004 | 04:18 PM
how about my stock sleeves?..is it still save and reliable?..thanks
Old Nov 1, 2004 | 05:46 PM
GDM Z28's Avatar
once again.....
Cliff notes: DONT PUSH IT! go stay stock bore you wont notice a difference.
Ericbalanzar
Feb 11, 2015 05:14 PM
the.hamburglar
Sep 29, 2005 05:59 AM
95civic_b20turbo
Jul 16, 2005 11:08 AM
ntegls
Feb 22, 2004 06:11 PM
TurboTeG4
Jun 18, 2003 03:47 PM
