JUST GOT SCREWED!!!
Old Oct 31, 2004 | 03:06 PM
DELTEGRA's Avatar
Default JUST GOT SCREWED!!!
I just got my jdm type r swap in my 93 delsol done, and the head casting is PR3-1. What head is this from?? It is supost to be a all original 98 j spec type r but the castings say 92-93 gsr (pr3-1) on the head did I get the bone or what?? PLEASE help!! thanks in advance, just about to have a heart attack here!!
Old Oct 31, 2004 | 03:18 PM
FatBoy4door's Avatar
Default Re: JUST GOT SCREWED!!! (DELTEGRA)
can you find any marking that sais p73 on the head?
keep in mind a type r head is a b16 head so the pr3 is there on all of them
Old Oct 31, 2004 | 03:30 PM
DELTEGRA's Avatar
Default Re: JUST GOT SCREWED!!! (FatBoy4door)
yea b16 and b18c5/ b18c-R have PR3-? on them but i thought that the PR3-1 was early head and the PR3-3 and PR3-4 ere the later models??
Old Oct 31, 2004 | 03:35 PM
six_speed's Avatar
if i rememebr correctly pr3-3 is a type r head.
revvin9k's Avatar
Hope this helps some I had a problem identifying my b18c from the jdm gsr motor and this sortof helped me. https://honda-tech.com/zerothread?id=888664
Old Oct 31, 2004 | 03:37 PM
WickedKP's Avatar
The block hould have B18C stamped on it. On the head there should be a P30 between the cam on the dist. side.you can see it without removing anything.
Old Oct 31, 2004 | 03:42 PM
Default Re: JUST GOT SCREWED!!! (WickedKP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Humping_dragon &raquo;</TD></TR><TR><TD CLASS="quote">if i rememebr correctly pr3-3 is a type r head.</TD></TR></TABLE>
my b16 head has pr3-3
Old Oct 31, 2004 | 06:06 PM
DELTEGRA's Avatar
Thanks for the info guys/gals I feel much better now that I know I didnt get jammed!! and yes it is a real R thank god!!
Old Oct 31, 2004 | 07:07 PM
nightrider's Avatar
if the motor is already in the car and you have driven it, you can instantly tell if it is a R motor.
Old Nov 1, 2004 | 07:10 PM
coolguy660's Avatar
So it should have a 30 between the dizzy and v-tech solenoid? or it shouldn't?
Old Nov 1, 2004 | 09:10 PM
#1151's Avatar
type r says PR3 as well...not p72...but as far as year...yea ide say you were screwed
Old Nov 1, 2004 | 09:35 PM
WickedKP's Avatar
Default Re: (coolguy660)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coolguy660 &raquo;</TD></TR><TR><TD CLASS="quote">So it should have a 30 between the dizzy and v-tech solenoid? or it shouldn't?</TD></TR></TABLE>
Yes. All factory Type R head are second gen. B16A Head, but with P&P. Thats why there is a P30 stamped between the cam. So if there isn't then it's probley a first gen B16A head. Then you should check really carefully. In another word you can get a GSR B18C jdm block put a Second Gen. B16A head. red valve cover, and a ITR intake man. and it would look so damn close to type r motor you would have to look very closely to tell the diffrent.
wwcrxww
Mar 26, 2014 04:13 PM
jdm0ua
Jan 13, 2007 09:50 AM
MotorMatrix.com
Feb 14, 2003 04:26 PM
blackR#663
Aug 19, 2001 06:15 AM
