what exactly does a cyp sensor do or fuction as?
Old Oct 31, 2004 | 02:13 PM
WickedWerx's Avatar
Default what exactly does a cyp sensor do or fuction as?
i know it says it is the #1 cylinder position sensor but what exactly does it mean and is it critical??? i have a code for it but car seems to be fine.....any ideas
thanks
M
Old Oct 31, 2004 | 02:16 PM
PyroProblem's Avatar
Default Re: what exactly does a cyp sensor do or fuction as? (WickedWerx)
It tells the ecu where the engine is at so it can orchestrate fuel and spark events...
I take it you got the engine running right... What was the problem?
Old Nov 1, 2004 | 01:18 PM
WickedWerx's Avatar
Default Re: what exactly does a cyp sensor do or fuction as? (PyroProblem)
i weas farting with the timing and forgot to put the jumper in the harness to reset it and what not then rewired the map and tps sensors and adjusted the tps....is the CYP a huge deal or what?? thanks
m
Old Nov 2, 2004 | 05:03 AM
EE_Chris's Avatar
Yes, its a big deal.
There are 3 sensors inside the distributor that synchronize all fueling and timing events: TDC, CYL, CKP
Old Nov 2, 2004 | 10:32 AM
WickedWerx's Avatar
Default Re: what exactly does a cyp sensor do or fuction as? (EE_Chris)
so whats it gonna do if i dont get it right? i have put 2 dizzys on it now and same **** but car is running ok so far so good.......thanks
m
yunghova3588
Feb 8, 2019 08:16 AM
hoopty8211
Feb 21, 2006 10:28 AM
snatch
Dec 13, 2004 04:28 PM
stivic
Oct 23, 2004 04:23 AM
wickedxboi
Oct 28, 2003 08:12 PM
