For DC2 (Non Type-R) Tein SS/Flex Owners-
Old Oct 31, 2004 | 10:06 AM
e629943's Avatar
Default For DC2 (Non Type-R) Tein SS/Flex Owners-
Hey all... for those of you that run Tein SS In your Integra (Prefably Gsr, just in case there are differences in the chassis/susp. setup), what is the minimum amount, in inches, you can drop the vehicle? I've been reading up on different facts everywhere, but I believe it is 1.6" in the front and .9" in the rear. Correct?
For FLEX, .3-3.6" in the front and .7-3.2" in the rear. The reason I'm asking is because I want the ride height of my integra close to stock as possible while having a different ride. Since the FLEX has independently adjustable spring preload and shock body length, does that mean that ride height is not proportional to stiffness in the ride?
If possible, I'd want to set up the ride height (using FLEX) to the minimum drop while retaining a pretty stiff setting. Any info and or advice is appreciated.
Thanks in advance for the info. $1300 for coil overs needs some time on the research lol
Matyikaaa90
Suspension & Brakes
Nov 23, 2015 11:09 AM
p-p-porkchop
Suspension & Brakes
Feb 5, 2006 08:05 AM
c_mack9
Suspension & Brakes
Jun 25, 2005 05:50 PM
yayabtech
Suspension & Brakes
Apr 5, 2005 05:58 PM
