b16 swap for customer, no spark
Old Oct 30, 2004 | 07:46 PM
gots_a_sol's Avatar
Default b16 swap for customer, no spark
im doing a b16 a swap for a customer and its all done, went to start, no spark
http://www.binghamtonlife.com/...3.jpg
i followed those instructions to test the ignitor, on step 7 i have a problem
I have no continuity between the blue wire and ground, i checked for any breaks in the wire up to the gauge cluster, and its fine, so it i have a bad ground somewhere, the valve cover is grounded, the trans is grounded and i now have 2 ground at the thermostat housing, just in case
ive been working this stupid car for about 2 weeks now, customer is getting antsy, wants his car back
Old Oct 30, 2004 | 07:56 PM
HatchBox's Avatar
Skoobie no more...
Default Re: b16 swap for customer, no spark (gots_a_sol)
dont know if this helps or not...
Old Oct 30, 2004 | 10:13 PM
gots_a_sol's Avatar
all those grounds are connected and secure, stupid hondas...
oh yea, the car is a 90 hatch dx
Old Oct 30, 2004 | 10:17 PM
HatchBox's Avatar
Skoobie no more...
no codes?
Old Oct 30, 2004 | 10:19 PM
gots_a_sol's Avatar
i dont think its throwing any, ill have to check again tomorrow when im not about to fall asleep on the keyboard
Old Oct 30, 2004 | 11:40 PM
DieMaster's Avatar
Needs to be About 20% Cooler
Default Re: (gots_a_sol)
i had a simalar problem and it turned out to be a bad engine - to - dizzy ground. i took off dizzy, and used a wire brush drill atachment and shined up the metal. never had a problem since.
Old Oct 31, 2004 | 02:15 AM
Turbo88hatch's Avatar
have you checked the ground thats on the thermostat? I had the same prob and it turned out be that one. Good luck
Old Oct 31, 2004 | 10:28 AM
gots_a_sol's Avatar
Default Re: b16 swap for customer, no spark (Turbo88hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo88hatch &raquo;</TD></TR><TR><TD CLASS="quote">have you checked the ground thats on the thermostat? I had the same prob and it turned out be that one. Good luck </TD></TR></TABLE>
i had a ground there already, i ran another ground from there straight to the battery though but it made no difference
ill try taking the dizzy off and doing that
the thing that gets me though, is this motor ran fine in the car it came out of(bought from I have an STD on here)
Old Oct 31, 2004 | 12:01 PM
I Have an STD's Avatar
wrenchin'
thought that was my motor. yeah man, it fired on two cyls the 1st time i statrted it, turns out two injectors were bad. so that motor has 4 good injectors on it now, i replaced all 4. i never had a check light and i NEVER had a prob with the motor not starting. fired up EVERY SINGLE TIME no questions asked. if u need any help let me know. ande should still have my number.
Brett
Old Oct 31, 2004 | 12:51 PM
gots_a_sol's Avatar
i think i bodged the wiring a bit,it sparks when the key is turned to the on position or when its turned off, not when its supposed to
ill mess with it later
Old Oct 31, 2004 | 01:30 PM
drussell4801's Avatar
Default Re: b16 swap for customer, no spark (I Have an STD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I Have an STD &raquo;</TD></TR><TR><TD CLASS="quote"> i never had a check light and i NEVER had a prob with the motor not starting. fired up EVERY SINGLE TIME no questions asked. </TD></TR></TABLE>
my motor usually doesn't ask me any questions either
LOL
Old Oct 31, 2004 | 01:57 PM
gots_a_sol's Avatar
i think i had the 2 white wires at the dizzy backwards, it doesnt spark when turning the key on anymore
but alas, it still doesnt spark when turning the engine over, grrr, im running out of **** to try and fix
Old Oct 31, 2004 | 03:50 PM
LoSt is BlaCk's Avatar
is there paint in the grounds...is that one ground to the starter connected?
Old Oct 31, 2004 | 04:33 PM
whizdumb's Avatar
Default Re: (LoStMyBoOsT)
My car wouldn't start because of a bad ignition coil even though it tested out fine. Couldn't figure out why it wouldn't start, every thing seemed fine and I followed the troubleshooting to the same thing you are -- bad ground. Did 2 grounds everywhere, then finally took it to a shop. They said it was the coil, replaced it and it fired up right away.
Old Oct 31, 2004 | 04:45 PM
RC000E's Avatar
Default Re: (whizdumb)
dude you f'd up the dual point conversion plain and simple. What harness is on the B16 first of all? You charge people to do swaps and you can't wire cars..damn man another person givin import shops a bad wrap. Man explain how you wired the car and which harness you used.
Old Oct 31, 2004 | 05:04 PM
kKdARIAN's Avatar
Vice President/CEO
Default Re: (RC000E)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RC000E &raquo;</TD></TR><TR><TD CLASS="quote">dude you f'd up the dual point conversion plain and simple. What harness is on the B16 first of all? You charge people to do swaps and you can't wire cars..damn man another person givin import shops a bad wrap. Man explain how you wired the car and which harness you used.</TD></TR></TABLE>
ouch...
good luck on the car bro'... keep us updated'
Old Oct 31, 2004 | 06:59 PM
gots_a_sol's Avatar
you dont even ******* know me, so dont say ****
its a 90 hatch dx, using the factory dx wiring harness, i used the how-to on 4thgenhatch.com, i went over the wiring twice already and its exactly how every ******* how-to shows
and im not a shop, though i'd like to have one someday, im just some average guy who enjoys working on cars, hondas in particular...having a decently stocked garage next to my house helps too
ill see if i can find a new coil locally and try that out, what kind of cars can i get that from? i dont really work on 4th gens that much so im not sure what other coils will work
Old Oct 31, 2004 | 07:02 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gots_a_sol &raquo;</TD></TR><TR><TD CLASS="quote">
you dont even ******* know me, so dont say ****</TD></TR></TABLE>
don't sweat that guy.
RC000E probably hasn't ever pulled a motor out of a car..
Old Oct 31, 2004 | 07:30 PM
onePOINTsix's Avatar
Default Re: (drussell4801)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drussell4801 &raquo;</TD></TR><TR><TD CLASS="quote">don't sweat that guy.
RC000E probably hasn't ever pulled a motor out of a car.. </TD></TR></TABLE>haha owned yeah best bet might even be to find another dizzy from like a 90-91 Teggie, it could randomly be the damn honda ignigtors, meh my .02
Old Oct 31, 2004 | 07:39 PM
wrenchin'
Default Re: (onePOINTsix)
i dont know man, i wouldnt try to find another dizzy, i literally drove the car to where i pulled out the motor. i doubt the dizzy went bad.
Brett
Old Oct 31, 2004 | 07:41 PM
Default Re: (I Have an STD)
you never know with honda ignitions man, they die so randomly
Old Oct 31, 2004 | 07:43 PM
gots_a_sol's Avatar
ill swipe one from the junkyard in the next day or so, big toolbox is good for throwing **** in...anybody need some resistor boxes?
and the bitch is, i just recently sold my old b16 dizzy from my sol oh well, **** happens
Old Oct 31, 2004 | 07:50 PM
gots_a_sol's Avatar
still need to strip that ugly *** valve cover
Old Oct 31, 2004 | 08:14 PM
Mackenzie's Avatar
ew, nasty valve cover
Old Oct 31, 2004 | 08:17 PM
gots_a_sol's Avatar
Default Re: (Mackenzie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mackenzie &raquo;</TD></TR><TR><TD CLASS="quote">ew, nasty valve cover</TD></TR></TABLE>
thats I Have an STD's friends' fault bead blaster will soon come back out of storage, i need to do the valve cover on my sol as well, all the stock **** is chipping off
