eg big brakes - need some info
Old Dec 21, 2001 | 07:47 AM
Doctor CorteZ's Avatar
Default eg big brakes - need some info
ok check dis-----
i work at an import salvage yard so i can compare anything needed -
i know of the prelude v-tec rotors redrilled to 4 x 100mm and the accord wagon calipers but am unsure which spindle/knuckles to use
so far i know that the integra gs-r and civic ex with abs brakes are around 10.3ish and they are different then my 93 si brakes
i want to know if anyone knows whether the angle and everything are the same on the 94 - up integras , they bolt up but i cant tell whether everything would be ok for alignment and **** - so anyone shed some light on this topic,let me know any thoughts you guys have and i'll start comparing this stuff -
thanks, Jamie
Old Dec 21, 2001 | 07:56 AM
chrisJ's Avatar
New User
Default Re: eg big brakes - need some info (quasimoto eg)
u can use 94+ integra complete brake/knuckle assemby and it will work just fine. simple bolt on brake upgrade
Old Dec 21, 2001 | 07:59 AM
Default Re: eg big brakes - need some info (chrisJ)
cool i just wasnt sure if it was the same as far as everything angle wise goes
anybody else runnin wagon calipers and lude redrilled rotors ????
Old Dec 21, 2001 | 11:23 AM
Mista Bone's Avatar
D Tranny Guru
http://www.fastbrakes.com
nickelz34
Aug 22, 2013 05:07 PM
keenspeed94
May 5, 2007 10:06 PM
eg:R
Aug 17, 2006 04:55 PM
youngsters69
May 12, 2004 05:50 PM
