Si final drive in a dx trans with OBX LSD?? good idea? possible? feedback?
Old Oct 30, 2004 | 04:58 PM
I Have an STD's Avatar
wrenchin'
Default Si final drive in a dx trans with OBX LSD?? good idea? possible? feedback?
ok, the dx tans was free, and the si trans has 4 gears that grind REAL bad and has a bad main shaft bearing. im thinking about swapping over the final drive fromthe si to the dx tans and then installing the new OBX LSD. im hoping to make a pretty sick-*** SOHC turbo tranny. not as long as a dx, but not as short as an si. car will be daily driven, so i want a decent tranny to drive around town with. but i also want a good tranny for the highway. HELP!! should i do this??
Brett
Old Oct 30, 2004 | 05:10 PM
wrenchin'
Default Re: Si final drive in a dx trans with OBX LSD?? good idea? possible? feedback? (I Have an STD)
bump!!! and i HAVE searched
Brett
Old Oct 30, 2004 | 05:28 PM
hatchback_al's Avatar
for sure. LSD rocks and i hear the obx one is pretty decent. but im sorry to say you will have an si tranny with lsd when you are done. All the gears are the same between the trannys the only difference IS the final drives. when u swap em you will have an SI tranny, good tranny imo!
Old Oct 30, 2004 | 05:41 PM
Stoich's Avatar
Default Re: Si final drive in a dx trans with OBX LSD?? good idea? possible? feedback? (hatchback_al)
hey bret i got my hatch back
hit me up on aim.
Old Oct 30, 2004 | 05:49 PM
EF9Si-T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchback_al &raquo;</TD></TR><TR><TD CLASS="quote">for sure. LSD rocks and i hear the obx one is pretty decent. but im sorry to say you will have an si tranny with lsd when you are done. All the gears are the same between the trannys the only difference IS the final drives. when u swap em you will have an SI tranny, good tranny imo!</TD></TR></TABLE>
I second that!
Old Oct 30, 2004 | 06:45 PM
d357r0y's Avatar
The SI tranny is just fine on the highway..
I recently got 35-37MPG round trip to Atlanta and back with an SI final drive in my SI/ZC hybrid tranny.
Old Oct 30, 2004 | 08:11 PM
skud_dusty's Avatar
Default Re: Si final drive in a dx trans with OBX LSD?? good idea? possible? feedback? (d357r0y)
So how hard would it be to swap the Si final drive into a DX tranny?
I've swapped out tranny's and differentials in my Neon...how hard would this be compared to that?
Old Oct 31, 2004 | 08:25 AM
wrenchin'
Default Re: Si final drive in a dx trans with OBX LSD?? good idea? possible? feedback? (skud_dusty)
thats actually pretty cool. i KNOW my dx trans is mint, so i guess now its just a matter of switching the FDs so i have a better tranny, does anyone have a write up on switching the FDs?
Brett
Old Nov 1, 2004 | 05:49 AM
d357r0y's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skud_dusty &raquo;</TD></TR><TR><TD CLASS="quote">So how hard would it be to swap the Si final drive into a DX tranny?
I've swapped out tranny's and differentials in my Neon...how hard would this be compared to that?</TD></TR></TABLE>
I've never worked on a Neon, but I'm gonna guess it's similar. I'd keep your original differential and just swap the final drive ring on there so you don't have to reshim anything.
1. open case
2. pull out parts you want
3. put them into the case you want
4. close case.
Old Nov 1, 2004 | 08:17 AM
skud_dusty's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d357r0y &raquo;</TD></TR><TR><TD CLASS="quote">
1. open case
4. close case.
Doesn't seem like it'd be too hard then...
Thanks
4DRmafia
16
Aug 25, 2006 05:59 AM
89civicsinKC
Feb 28, 2005 05:28 PM
ebelp
Jul 25, 2004 06:27 AM
Jet Black
16
Jan 7, 2004 10:40 AM
K20EG
Oct 9, 2003 02:00 AM
