Optima Battery ?
Old Oct 30, 2004 | 01:17 PM
JDMSpoonType-R's Avatar
Default Optima Battery ?
Hello,
Do any of you guys have an optima battery? If so, Red or Yellow Top and what size did you get? I'm trying to find out what size and which color I should get.
Thanks
Old Oct 30, 2004 | 01:35 PM
Mugen Mike's Avatar
Default Re: Optima Battery ? (JDMSpoonType-R)
Yes, yellow top. OEM size.
Old Oct 30, 2004 | 02:58 PM
Bbasso's Avatar
Plenty of info here on batteries,
https://honda-tech.com/zerothread?id=685094
Also maybe this post should be added to the FAQs?
Old Oct 30, 2004 | 03:51 PM
SLCTyper's Avatar
To the best of my knowledge, Optima doesn't make an OEM size Red Top for the ITR. I have a yellow top that is though.
Old Oct 30, 2004 | 07:19 PM
5 Lug's Avatar
Default Re: Optima Battery ? (SLCTyper)
I've got the yellow top and the above post was correct, they don't make a red top that's Honda/Acura OEM size.
Old Oct 30, 2004 | 08:14 PM
Default Re: Optima Battery ? (5 Lug)
Heys guys thanks for all the info.........greatly appreciated. I guess Yellow top it is.
Old Oct 31, 2004 | 07:16 AM
Dr Pooface's Avatar
Don't waste your money, get a hawker.
Old Oct 31, 2004 | 08:16 AM
DsITR's Avatar
Default Re: Optima Battery ? (Dr Pooface)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr Pooface &raquo;</TD></TR><TR><TD CLASS="quote">Don't waste your money, get a hawker.</TD></TR></TABLE>
amen
more info here
https://honda-tech.com/zerothread?id=734430
Old Oct 31, 2004 | 08:20 PM
Bigwool's Avatar
I've worked for interstate batteries for 3 years and i have a yellow top in my R. They only makea yellow top in the 51 size. Your gonna have to get the SC-51R. Its definantly worth the money
Old Nov 1, 2004 | 06:26 AM
Philly_NBP_R's Avatar
Default Re: Optima Battery ? (Bigwool)
Unless your running a serious aftermarket stereo setup, the Optima battery is overkill for an ITR. Those things weigh a freaking ton (40+ lbs or something). Just stick with stock or interstate/die hard battery (~26lbs) or get a braille battery if you want something lightweight (12lbs).
More info on the braille battery here:
https://honda-tech.com/zero...age=3
and here:
http://www.brailleauto.com/bra...y.htm
I've been running my braille everyday for about six months now with no issues. Check back in the spring to see how it did during the winter.
Old Nov 1, 2004 | 06:34 AM
Bradstard's Avatar
Default Re: Optima Battery ? (Philly_NBP_R)
For some reason my ITR battery would only last a year. I would have to replace them every year when it started to get cold (I know they should last longer). I don't have a "big" system, just a 400 watt amp and sub. I've had the Optima for over a year now and it turns over just as though it were new. Even if the car sits for a 2 months....I would recommend one.
Old Nov 1, 2004 | 07:39 AM
Mugen Mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Philly_NBP_R &raquo;</TD></TR><TR><TD CLASS="quote">Unless your running a serious aftermarket stereo setup, the Optima battery is overkill for an ITR. Those things weigh a freaking ton (40+ lbs or something).</TD></TR></TABLE>
Not the OEM sized Optima battery. It weighs about the same as a stock battery.
Old Nov 1, 2004 | 07:45 AM
Default Re: Optima Battery ? (Mugen Mike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugen Mike &raquo;</TD></TR><TR><TD CLASS="quote">Not the OEM sized Optima battery. It weighs about the same as a stock battery.</TD></TR></TABLE>
&lt;=== didn't know they had an OEM size Optima...
Old Nov 1, 2004 | 08:13 AM
Stinkycheezmonky's Avatar
Suspetise...
$167 for a battery? Holy crap.
Old Nov 1, 2004 | 08:30 AM
Bradstard's Avatar
Default Re: Optima Battery ? (sscguy)
I paid $109 at Pep Boys about a year ago for mine.
Old Nov 1, 2004 | 08:33 AM
Mugen Mike's Avatar
There's a picture of one a few posts up.
Old Nov 1, 2004 | 08:58 AM
Suspetise...
$109 even, damn. I got my AutoZone Silver something or other for like $30. I don't care about battery power enough to spend an additional $79...
Old Nov 1, 2004 | 09:04 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sscguy &raquo;</TD></TR><TR><TD CLASS="quote">$167 for a battery? Holy crap.</TD></TR></TABLE>
it weighs 12 lbs and has 700 pulse cranking amps...
I got mine for $118 on a groupbuy.
Old Nov 1, 2004 | 10:39 AM
Suspetise...
Given that I don't race competitively, that still does not justify the benefits. Just my opinion though, I guess it works for some people.
Old Nov 1, 2004 | 11:57 AM
KayOs's Avatar
Which reminds me .....I need a new battery as well. Woke up this weekend to a dead battery on the R. I need a battery with enough cranking amps for northeast winters....
Old Nov 1, 2004 | 12:01 PM
People_Mover's Avatar
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
Default Re: Optima Battery ? (KayOs)
red tops are garbage.
I had a yellow top on my civic running 3 car audio amps and it never gave me a problem.
Old Nov 1, 2004 | 12:58 PM
5 Lug's Avatar
Default Re: Optima Battery ? (People_Mover)
Yea, despite the rumors of the Optima weighing a ton, it was exactly 4 pounds LIGHTER than the battery that was in there when I bought the car. (Die Hard I think?). I had good experience with them in the past as a reputable company and I wasn't buying a battery for weight savings so the Optima suited me fine.
Old Nov 4, 2004 | 11:55 AM
iperez's Avatar
Yellow-top here too !! Have had it for about 3 months and it works nicely .. no complains
Confirmed: No red-top is available in OEM size ..
Old Nov 4, 2004 | 02:31 PM
CWTegRNo.160's Avatar
Default Re: (iperez)
my yellow top is under all that crap over there.
Old Nov 4, 2004 | 02:42 PM
Dan GSR's Avatar
I love the reliablity
